Author Topic: Simple shortwave wire antenna in a room - best method to string it up?  (Read 1676 times)
Offline A.Z.
Re: Simple shortwave wire antenna in a room - best method to string it up?
« Reply #25 on: March 23, 2024, 03:48:56 pm »
well, willing to use the simplest antenna, one may build an aperiodic one, just pick a lenght of coax, the longer and fatter, the better; short the center and braid at one end using a resistor with a value near the characteristic impedance of the coax (e.g. 50 Ohm), next place a coax connector to the other end, but wire it "reversed", that is; the coax braid to the center and the coax center conductor to the connector "gnd", lay out the wire as possible and give it a try :) possibly using a run of regularly wired coax to feed it (through a choke) and connect it to the receiver
« Last Edit: March 25, 2024, 03:43:56 pm by A.Z. »
