Author Topic: RF 433Mhz module  (Read 3174 times)
Offline victorgozman
  • Country: ng
RF 433Mhz module
« on: February 02, 2016, 08:59:51 pm »
please I bought a  RF module(RB-Ite-108)  that operates at a frequency of 433Mhz. please I need to find out which Rf protocol it uses for communication. A picture of the module is attached below.
Offline Kilrah
Re: RF 433Mhz module
« Reply #1 on: February 02, 2016, 09:05:34 pm »
It doesn't use any, you have to specify one yourself.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: February 02, 2016, 09:09:15 pm »
send it 5-10Kbps digital pulses, the other end will receive the same...
Offline JimRemington
« Reply #3 on: February 02, 2016, 09:30:25 pm »
Many people use ATMega328/Arduinos and the VirtualWire or RadioHead libraries (i.e. driver code) with those modules. http://www.airspayce.com/mikem/arduino/VirtualWire/
I've used them for years for remote environmental sensors. They work pretty well, with a range of up to 300 meters using proper balanced dipole antennas.
  • Country: ng
« Reply #4 on: February 02, 2016, 09:32:47 pm »
Thanks for your repies. pls does it make use of any radio frequency standard such as WiFi, ZigBee, zwave etc.
Offline Kilrah
« Reply #5 on: February 02, 2016, 09:34:49 pm »
No.
  • Country: my
« Reply #6 on: February 02, 2016, 09:47:26 pm »
Wifi is 2.4GHz yours is cheap china 433MHz what are you talking about? want a wifi? buy 2.4GHz transmitter. this cheap china is protocol heaven you can do whatever you like if you are up to it, this is the old school radio modulation... but only 433MHz carrier, hence signal must be much slower than that, you send it 1Mbps, it'll only good for mm transmission..
