From PN 11729C-2
The baseband signal is further processed through a Low Noise Amplifier (LNA)...
The amplifier has approximately 40 dB of gain (coupled into 50 ohms) and a bandwidth of about 10 Hz to 30 MHz. Typical flatness is less than 1 dB and the noise figure is less than 2.0 dB.
