Author Topic: Knob Wanted! (Trio TR-2300). Kindly donated by Paul, thank you!  (Read 392 times)
Offline christopher iles
Hello,
Have you got a volume or squelch knob for a Trio TR-2300 please?
Kind regards,
Chris, G0VOE.
« Last Edit: June 06, 2020, 08:57:28 am by christopher iles »
Online m3vuv
Re: Knob Wanted! (Trio TR-2300).
« Reply #1 on: May 20, 2020, 09:12:30 am »
hi chris,ive some knobs on an old scrap tr-9000,would they fit?,cheers Paul m3vuv.
« Reply #2 on: May 21, 2020, 08:11:51 am »
Hello Paul,
Thank you very much for your reply. I am sure that some of the TR-9000 knobs are virtually identical so should fit.
The shafts on the TR-2300 are all 1/4" diameter.
I have just finished replacing the synthesiser on the '2300 with an old CB one (MC145106) and now have 12.5 KHz spacing and it works great.
I have changed the meter and dial lamps to l.e.d. reducing current drain when on batteries
The CTCSS board is also in now so basically the rig is now up to modern standards.
Been a bit fiddly, but fun to do and IT WORKS!
Just the missing knob that spoils it now.
Kind regards,
Chris. G0VOE.
Online m3vuv
« Reply #3 on: May 21, 2020, 12:46:15 pm »
i will post a couple on sat chris ok
« Reply #4 on: May 22, 2020, 06:08:09 am »
Hi Paul,
Thanks ever so much, that's really kind.
Should you ever get stuck for a part, I will be more than happy to return the favour if I can.
My address:
Moon Cottage,
2,Mountview Terrace,
Pawlett,
Somerset.
TA6 4SL.
If you put your address on I will refund the postage to you.
Thanks again and kind regards,
Chris, G0VOE.
Online m3vuv
« Reply #5 on: May 25, 2020, 03:04:42 pm »
they are ready to post in the morning.
Online m3vuv
« Reply #6 on: May 28, 2020, 02:23:42 am »
posted yesterday royal mail 1st class ok.
Online m3vuv
« Reply #7 on: June 03, 2020, 05:53:36 am »
have you received them yet?
