Hello,
I´m design a board with Nordics NRF9160 to collect some data from a few sensors, i have already made a few boards for testing, but i´m having a problem with the LTE radio on it, it´s having a hard time obtaining and mantaining a connection to the tower, it takes a long time for making one and when it does the signal is so bad i can´t talk with the tower, or the connection drops after a few seconds. It also has GPS wich can get a fix and it´s working.
I´m using a flat antenna just like ANT-LTE-RPC-UFL from Linx, the antenna is connected via a IPX connector.
My board is quite small 24 mm (0.9') x 45 mm (1,77´), so i´m thinking maybe my ground plane is too small, i don´t have much experience with RF.
Here is my board:
Any suggestions on what could i do to try to solve my problem with the signal ?
