Author Topic: WWVB receiver advice  (Read 17754 times)
Offline uncle_bob
Re: WWVB receiver advice
« Reply #25 on: February 25, 2016, 12:18:13 am »
Seems like a good time to drop this link: http://toroids.info/
Hi
Look very carefully at the core materials. Some are designed for power applications where tight stability specs are not at all common. For filters, you need a material that has good temperature stability *and* adequate Q *and* can be wound without going nuts.
In some cases, wonderful stuff like Litz wire comes into the mix as well.
Bob
Offline NivagSwerdna
« Reply #26 on: March 01, 2016, 12:22:05 pm »
Have you seen this
Nice receiver
Offline uncle_bob
« Reply #27 on: March 02, 2016, 02:13:16 am »
Have you seen this
Nice receiver
Hi
WWV != WWVB
60 KHz != 10 MHz
Bob
« Reply #28 on: March 03, 2016, 01:19:09 am »
WWV != WWVB
60 KHz != 10 MHz
Ah! Apologies.
Here in the UK we have similar and the easiest solution is an off the shelf module...
e.g.
http://www.pvelectronics.co.uk/index.php?main_page=product_info&products_id=7
but actually the MSF60 signal here is difficult to receive especially around computer equipment, the DCF77 signal from Germany is better.
However, if you have line of sight to the sky GPS is far easier.
