Author Topic: TESTS on LMX2820 45MHz-22.6GHz Wideband Synthesizer Module  (Read 2114 times)
Offline jaudetTopic starter
    • Electronics and  Amateur Radio  WEB  SITE
« on: November 13, 2024, 08:49:12 pm »
I ran measurements on the LMX2820 Synthesizer Module, as available on EBay and AliExpress.  Will add ALC + Amplifier circuit to stabilize and increase the output.
On my web site:  http://ve2azx.net/technical/LMX2820_Tests.pdf
The following users thanked this post: wilspang
Offline EggertEnjoyer123
Re: TESTS on LMX2820 45MHz-22.6GHz Wideband Synthesizer Module
« Reply #1 on: November 23, 2024, 04:32:45 am »
The cheap boards suck in terms of phase noise because they copied the loop filter without changing the crystal (which is 10MHz).
The optimum phase noise is achieved by using a high frequency crystal (like 100 MHz), which increases the phase detector frequency.
Offline max-bit
« Reply #2 on: December 10, 2024, 04:42:50 pm »
Price on aliexpress ~$250
« Reply #3 on: December 11, 2024, 04:26:31 am »
The price is not worth it, especially since their circuit has mistakes.
The LMX2820 can be bought for around $50 each at LCSC.
