Author Topic: The N Connector, question  (Read 689 times)
Offline Randy222Topic starter
« on: November 24, 2025, 12:22:45 am »
Std practice everywhere, ID threading is female, OD threading is male.
N has male pin in a female threading, and a female pin in a male threading.
So which end if the N connector is the "male" end?
Offline abeyer
Re: The N Connector, question
« Reply #1 on: November 24, 2025, 01:01:10 am »
Umm... F? SMA? UHF? Doesn't seem standard at all in common coax connectors.
Offline fourfathom
« Reply #2 on: November 24, 2025, 01:09:39 am »
I believe, with no authoritative source, that a male connector has an inner pin (or wire in the case of the F connector), and the female has a socket for that pin.  The shell threads or connecting mechanism are irrelevant to the male / female designation.
Now someone please show us where this is not the case.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Online TimFox
« Reply #3 on: November 24, 2025, 03:46:31 am »
Another example of a male pin insert inside a female "outsert" are the BNC bayonet and the TNC threaded connectors.
Both are generally called "male", and are usually on the cable.  Panel-mount male and female BNCs are available.
Offline Andy Chee
« Reply #4 on: November 24, 2025, 03:54:08 am »
UHF male has ID thread, UHF female has OD thread.
Complete opposite to your so-called "standard practice".
« Reply #5 on: November 24, 2025, 05:23:51 am »
Ok, so it's all based on the pin.
To me, the actual base std should be like the RP connectors where the female pin is in the shell of ID threading.
Offline Andy Chee
« Reply #6 on: November 24, 2025, 07:41:47 am »
Oh yes, those SMA connectors are confusing!
Offline Davecbyp
« Reply #7 on: Yesterday at 02:17:18 pm »
The historical engineering view, esp. Manufacturing, is the Male is the one attached TO the Female, i.e. " which half is best mounted to an assembly, and which on a cable."
Yes, generally ' pin fitting into hollow mating contact' defines it, untill its a Reverse pair, or, a connector shell system has multiple arrangements for keyng.
Ultimately, its how Manufacturing sees it, cause they have to build it.
The following users thanked this post: Randy222
Online mtwieg
« Reply #8 on: Yesterday at 11:28:27 pm »
My general rule thumb on determining connector gender:
Imagine you're presented with both genders of the connector, and the contacts are all energized with 1000V (except the shield, if there is one)
Choose which connector you would rather lick
That's the female
Works in almost all cases. RP-SMA is one exception
« Last Edit: Today at 01:29:27 pm by mtwieg »
« Reply #9 on: Yesterday at 11:38:20 pm »
SMA "RP" is almost meaningless.
You can have male sma in male shell, and then RP that, so that male-rp is basically a sma-female.
Just use std, human anatomy for shell, then specifc the pin. male-male, female-male, etc, simple.
shell-pin spec, and skip the RP nonsense.
Offline fourfathom
« Reply #10 on: Today at 02:51:21 am »
Is there a rational reason why we even have RP SMA?
Offline Geoff-AU
« Reply #11 on: Today at 03:19:29 am »
To keep WiFi meddlers away from the real radio gear  :P
Online ejeffrey
« Reply #12 on: Today at 03:20:33 am »
RP connectors are just a polite fiction for FCC compliance with detachable antennas.  It's used in consumer ISM band equipment to discourage unlicensed operators from attaching amplifiers or high gain antennas rather than what the manufacturer provided.
Obviously it won't stop anyone determined, but it adds one step between "dur, I can get a 40 dBm amplifier from minicircuits, that will overclock my wifi like crazy"
