American CB radio "techs".
I believe in "trust but verify" but at the start all of the meters to measure the same thing..... no trust in the gear? needs 5 meters?
And why does reflected power of a dummy load (I hope) have anything to do with the radio?
That doesn't compute, just like the bank of meters... it seems more for show.
But there is emphasis on reflected power. What is the DUT? Is it the radio, antenna/dummy load, or feedline?
Most of the video is look at this meter look at that meter.....
Let's talk about mass production but... not actually know how its done, because robot arms don't solder every joint.....
Cant believe that unskilled labourers can solder badly. Ok.
There are some just absolutely crazy moments. Like the speaker impedance thing and needing ferrite because of impedance. WUT?
At the end, the am envelope looked very bizaare, and seemed to barely break 50-60% modulation. clearly a misadjustment and/or circuit fault.
I want to see the guy that was transmitting from 24-30 Mhz at the same time. That's got to be an impressive feat of misadjustment and/or synthesiser hackery.
In the end it was 95% theatrics. Serious hints at narcissism. All the "we" - Mouse in the pocket, etc.
I am still trying to get my head wrapped around the emphasis on reflected power having anything to do with the DUT - which is clearly the radio.
Talked about spectrum and made a pretty out there claim but clearly doesn't have an SA so it's just conjecture.
He needs to check his feedlines, those meters, and his dummy load. There is an issue. It's probably all the bloody meters in line.
Not missing anything here. Nothing to see.... move along.....
