No RX when signal put in and I do have transmit but it is low.
No receive on all modes & when connected to load with no signal injected on USB Signal Meter goes to S9, LSB S3, CW S4. AM FM & PA S0
Unit is only putting out dead key 2.5w and 28w modulated on AM, USB & LSB 26w modulated. That’s with amp in line, when I pull the J22 amp key I’m seeing 0.3w dead key and 3.5w modulated.
