Electronics => RF, Microwave, Ham Radio => Topic started by: SpencerTC on August 14, 2018, 05:31:50 am
Title: Unfamilar coaxial connector
Post by: SpencerTC on August 14, 2018, 05:31:50 am
Hello all,
I was cleaning up the lab at work today and ran across some coax connectors that are unfamiliar to me. They have a relatively small outside diameter of 5mm and an odd collar that looks like you pull back on (reminds me of a compressed air quick disconnect) to release 2 barbs that seem like they would lock it in place with the female version. Can anyone tell me the name of these connectors? Their primary uses? Assuming they are used for RF/MW what frequencies could one expect out of them reliably?
I'm mostly just curious, as I don't have anything to use with them, it would be nice to know in case I ever run into a case where they may be required though.
Thanks in advance,
Trent Spencer
Title: Re: Unfamilar coaxial connector
Post by: helius on August 14, 2018, 06:05:00 am
Looks like a push-pull connector from Lemo, Fischer, or Redel, or a knockoff from the far east. These types are not very commonly used.
Post by: Alex Eisenhut on August 14, 2018, 07:05:11 am
LEMO .00 connector, used by the bucket in NIM.
https://ndt.nu/index.php?item=lemo-00-equ_-------lemo-1-equ_--cable_s_&action=article&aid=91&lang=en
https://en.wikipedia.org/wiki/Nuclear_Instrumentation_Module
Post by: SpencerTC on August 15, 2018, 05:18:52 am
Wow, that is even more unusual than I was expecting.
I'll keep it in my kit in case I ever run across a need for it, but I don't expect that to happen.
Thank you for your response, I doubt I would have ran across that information myself.
