However, if you slowly increase the voltage across one pair of connections until you get a discontinuous change in current and possibly smoke....
Ahhh, destructive testing. The one test to rule them all. Yes, all attenuators will look electrically identical from both ends, but I would imagine it's the power rating of the resistor network that makes them uni-directional.
Well, I posted a few questions and now have some replies.
Asked on Amazon (they sell attenuators on there) and was told by an RF 'Engineer' that all attenuators are bi-directional....I'm guessing here that he's only ever used decent kit, and the company he worked for never ordered from Eby or Ali. Which would explain the answer.
Went hunting on Ali, and found a seller that claims to be a
manufacturer - RFteleworld. To my surprise, they understood my question and offered a coherent reply. Most of their (cheaper) 3G/4G stuff in the 2-50W range is uni-directional (
male input and female output), but the 6G stuff in the 2-50W range is bi-directional. The 6G offerings are about 2x the price of the 3G, but still 10x less than anything branded like Bird.
Kind of important to know because most analyzers have a female panel mounted N port. If you hang an attenuator of this connector as I've seen many people do, then the uni-dir will be the wrong way round, and will burn out at rated value. Incidentally, none of this directional info is posted on the sales pages on Ali. You have to ask.
I've put an order in. Lets see what arrives.
