Author Topic: Upcoming Keysight Webinar  (Read 1629 times)
Offline xmoTopic starter
« on: June 06, 2021, 04:35:38 pm »
I received this email that I thought might interest other RF junkies:
Demo: PNA-X Spurious Test
Dr. Joel Dunsmore will walk through a 20-minute demo showing optimized spurious testing with the enhanced PNA/PNA-X new DDS source.
In this webinar series Dr. Dunsmore will demonstrate:
•   Close-in carrier spurious
•   Higher-order mixing products
•   Spurious vs. LO drive level
Join this Keysight webinar to learn how to optimize spurious tests on the PNA/PNA-X.
Date: June 16, 2021
https://connectlp.keysight.com/SpuriousTest-Americas?elq_cid=1130946&cmpid=ELQ-14600&elqCampaignId=14600&elqTrackId=2FE217D7C4FF72BD38DC574DD1E4E6B9&elq=ba1aa6467a24496da8e3fb5eff8200a8&elqaid=30097&elqat=1&elqCampaignId=14600
Offline joeqsmith
Re: Upcoming Keysight Webinar
« Reply #1 on: June 06, 2021, 09:26:32 pm »
uBlock Origin has prevented the following page from loading:
Odd.
Offline jjoonathan
« Reply #2 on: June 07, 2021, 12:16:31 am »
I got a "confirm your country" modal -- maybe that's what upset uBlock?
Offline A.Z.
« Reply #3 on: April 26, 2022, 12:05:34 pm »
Odd.
not so much, the message explains that the domain is on a "blacklist" due to privacy issues, it probably collects fingerprints and data and sells them
Offline cdev
« Reply #4 on: April 26, 2022, 12:29:51 pm »
Ublock Origin, which I also use, can subscribe to a bunch of ad oriented lists. You can select which ones you want to use.. But cannot edit them. (unless you do so and put the new list on your own server, which isnt hard)
Offline cdev
« Reply #5 on: April 26, 2022, 12:32:32 pm »
Chance is, the first part of the URL is okay, its usually the part after the ? that I find likely to be problematic/privacy endangering..
Date: June 16, 2021
