At work I've had access to T-Tech or LPKF milling/routing machines for about 25 years. They do work very well if you want to make a quick prototype circuit on Rogers 4003 or 4350. About 12 or so years ago I bought my own (used) T-Tech 7000S machine to use at home and it is still working really well. You can pick these machines up quite cheaply but you run the risk of buying one that will be worn out or damaged. If you want to buy one of these then it's best to be very very patient and wait for a bargain. I bought a second 7000S machine about 10years ago just for long term spares backup.
Thanks, I'll keep a lookout for the T-Tech. I can image that Teflon laminates are quite hard to mill but with the current performance of Rodgers materials I'm not really looking into other laminates right now.
I actually found a bargain Chinese CNC6040 with a Kress 1050W router on eBay which was modified by its previous owner for more stability. However, it never arrived. My intention with this machine was also to mill out some waveguide parts/feeds/slot antenna. Mostly WR90 and above. I was looking into milling some WR12 for work.
But for PCB's I was worried about the Z-axis stability.
I guess the T-Tech Z-axis is stable enough since you've been using it for quite some time?
Are you aware of http://microwavers.org/ ? Many back issues of their newsletter are available free of charge.
There are some microwave transverter designs/ideas here: http://www.croatia-microwave.blogspot.com/
I know both sites quite well
Last time I went on Holiday I downloaded a bunch of old Scatterpoints to read.
I have the feeling more recent issues are a little less technical though.
Haven't tried them myself yet, but this is the cheapest place I have found in Europe for RO4003:
http://www.micron20.com/en/orders/calculator-production
~94 EUR for 5 pcs 100x80mm
Thomas
And we have a winner for some prototypes! Very nice.
