IC-705.zip (4.14 kB - downloaded 104 times.)
IC-705.zip (4.14 kB - downloaded 104 times.)Hi,
Attached is IC-705.ini file for the
RS-BA1 Version 1 software As this version1 does not support IC-705 transceiver.
It will add this rig with USB support and if you choose baud rate of 115200 then it will enables the
Spectrum Scope with some what limited functions.
copy this IC-705.ini file to following path
C:\Program Files (x86)\Icom\RS-BA1\RemoteController\models\
and enjoy.
Brgds.
73 de vu2ehy
