Hi Georgi, I think your assumption is correct, you are getting some processing gain from the DSSS demodulator. If for example the chip rate is 100 times the bit rate, then by definition, the processing gain equals chip rate/bit rate, equals 10log(100)dB or 20dB. The received psuedo noise, PN, sequence correlates in the receiver to give data bits whereas AWGN doesn't correlate. Perhaps, and I'm thinking aloud, the receiver bandwith, or I should say receiver equivalent noise bandwith is determined more by the correlator rather than the front end RF bandwidth. Also, if the DSSS modulator is BPSK then you would get 3dB gain because both sidebands are identical and the AWGN isn't. I know I have over simplified things, processing gain is only part of the equation.
