Continuing my experiments with low power, unlicensed broadcast FM, I'd like to get an idea of just how much power I'm actually putting into the air.
I'm using an si4713 for the transmitter. It claims it can push out 115dBuV (120dBuV if I'm not interested in voltage stability) and just have a 120nH high-Q (thanks BrianHG!) inductor as shunt, feeding 6cm of wire. (I've also tried longer lengths, but this seems to work the best.)
When the transmitter board is powered off of a wall wart, I get really good performance. Maybe a hundred feet, which is pretty snazzy.
When powered off of a regular old 18650 lithium cell, I can't even get 10 feet. I *suspect* that it's got to do with a lack of solid ground, and will be experimenting with a dipole antenna (basically two 6cm lengths of wire, one grounded, one the driven element, in a kind of "T" shape).
That's all backstory. What I'm really trying to do is figure out how to measure the field strength of the transmitter+antenna. I've found a little circuit (
http://lowpowerradio.blogspot.com/2010/12/field-strength-meter-for-fm.html) which will probably get me in the ballpark but I am not sure how to "tune" it to ensure it's MY transmitter I'm measuring and not, for example, the local college FM radio station.
Is it "just" a matter of inserting an appropriate filter in front of the meter so only the frequency I'm interested in makes it through? It seems that that would be difficult given how narrow FM is and how closely the stations are packed. I am not sure if I can equate the dBuV that the transmitter chip is creating with an actual field strength in uV/m measured 3m from the transmitter with a "standard" antenna (whatever that means).
Any tips/ideas/guidelines/interesting stories are very much welcome.
