I got the offer from Spinner (Keysight / R&S OEM):
Spinner 533828 -- 950USD + Tax etc. --Datasheet Attached
OSLT 3.5mm female (IEC 60169-23) connector, 0-13GhzPhase match open:
0 - 4 GHz / 1,5° max.
>4 - 8 GHz / 3,0° max.
>8 - 13 GHz / 4,5° max.
Phase match short:
0 - 4 GHz / 1,0° max.
>4 - 8 GHz / 2,0° max.
>8 - 13 GHz / 3,5° max
Load, return loss
0 - 4 GHz / 40 dB min.
>4 - 8 GHz / 34 dB min.
>8 - 13 GHz / 28 dB min.
Thru, return loss
0 - 4 GHz / 34 dB min.
>4 - 8 GHz / 28 dB min.
>8 - 13 GHz / 25 dB min.
Spinner 533882 -- 2100USD + tax (Out of my league) --Datasheet Attached
OSLT 3.5mm female (IEC 60169-23) connector, 0-26.5GhzPhase match open:
0 - 5 GHz / 1,5° max.
5 - 15 GHz / 3° max.
15 - 26,5 GHz / 4,5° max.
Phase match short:
0 - 5 GHz / 1° max.
5 - 15 GHz / 2,5° max.
15 - 26,5 GHz / 4° max.
Load, return loss
0 - 5 GHz / 42 dB min.
5 - 15 GHz / 36 dB min.
15 - 26,5 GHz / 32 dB min.
Thru, return loss
0 - 5 GHz / 34 dB min.
5 - 26,5 GHz / 30 dB min.
Rosenbergs 03K30R-MSOS3 850USD (quote)
26.6GHz 3.5mm female (IEC 61169-23) connector
Specs for comparison:Open
Error from nominal phase
1 ≤ 1.0°, DC to 4 GHz
≤ 2.0°, 4 GHz to 8 GHz
≤ 3.0°, 8 GHz to 26.5 GHz
Short
≤ 1.0°, DC to 4 GHz
Load
Return loss ≥ 40.0 dB, DC to 4 GHz
≥ 35.0 dB, 4 GHz to 8 GHz
≥ 30.0 dB, 8 GHz to 26.5 GHz
In conclusion:The Rosenberger OSL costs slightly less then the Spinner 0-13GHz version. It lacks the throu standard (which seems likt the easiest-to-replace standard to me), goes to 26GHz and has better phase specs for the open and short but a significantly better return loss for the load. Only bummer is 12-13 weeks of indicated delivery time
So far I lean towards the Rosenberger. Any objections?
EDIT: Mixed up Short and Thru for Spinner kits. Fixed.
