Author Topic: WATERPROOF SMA CONNECTION  (Read 2730 times)
Offline scanforTopic starter
« on: November 26, 2024, 03:02:16 am »
I have a wet application where a sensor is mounted in an underground pit that can fill with water after rain.
The sensor is fitted with a waterproof SMA connector, so the moisture doesn't enter the housing of the sensor.
However, the coupling between the antenna lead and the sensor is getting wet and corroding.
Is there a way of waterproofing that point of connection?
I've considered some form of conformal coating, but I'm hoping there is a more elegant and field-repairable option.
Any help would be greatly appreciated.
Scott
Offline Poroit
Re: WATERPROOF SMA CONNECTION
« Reply #1 on: November 26, 2024, 03:23:57 am »
G'day Scott,
Can you Heat shrink it and then wrap it with Self Amalgamating or Denso Tape?
« Reply #2 on: November 26, 2024, 03:27:53 am »
Thats certainly one option, and would probably work.
My main issue is that ham-fisted gorillas may be working on these and based on past experiences, they sometimes don't take as much care as they should, so I'm looking for a "foolproof" solution. ::)
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #3 on: November 27, 2024, 11:26:43 am »
SMA isn't optimal for ham-fisted gorillas anyway. Are you sure it can't become N type?
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #4 on: November 27, 2024, 11:45:54 am »
Some sensors come with a pigtail in order to locate the first connector in a better place.
Regards, Dieter
The following users thanked this post: scanfor
Offline Poroit
« Reply #5 on: November 28, 2024, 06:17:01 am »
G'day Scott,
Can we see a pic of the sensor?
Offline Kean
    • Kean Electronics
« Reply #6 on: November 28, 2024, 10:20:57 am »
There are some SMA rubber boots available on the market.  Not sure how waterproof they are, and if they will protect from submersion.
e.g. https://gammaelectronics.net/products/sma-rf-weatherproof-boot
Offline richnormand
« Reply #7 on: November 28, 2024, 11:05:32 pm »
"There are some SMA rubber boots available on the market.  Not sure how waterproof they are, and if they will protect from submersion.
e.g. https://gammaelectronics.net/products/sma-rf-weatherproof-boot"
Looks like the beginning of a good solution Kean. Assuming the case and connector are actually waterproof I would take the rubber boot and fill it with RTV silicone.
After putting it in place I would make sure all the seams are full and oozing some RTV out. Let it dry and cut the excess.
being RTV you could dismantle it in the future if needed.
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Online Solder_Junkie
« Reply #8 on: November 30, 2024, 10:21:58 am »
You can use either "non acidic" silicon rubber solution, or liquid electrical tape. The silicon rubber solution is specifically manufactured to be safe on electrical equipment, as opposed to the bathroom type which will at least tarnish, or worse still, corrode metal.
Liquid electrical tape is rubber dissolved in a strong solvent, which comes in a jar or tin with a brush in the lid.
With either of these, you can over wrap with self amalgamating tape for physical protection, don't try to coat self amalgamating tape with liquid electrical tape as the solvents dissolve the rubber tape.
Use a torque spanner to tighten the SMA plug (8mm, 0.5Nm), they are widely available and not expensive.
SJ
Offline Smoky
« Reply #9 on: November 30, 2024, 05:58:29 pm »
These SMA connectors have silicone rubber gaskets in them:
Maybe SV Microwave has a similar SMA connector to use with your specific cable :-//
Offline tooki
« Reply #10 on: November 30, 2024, 06:37:01 pm »
All SMA connectors have a gasket, since it is required by the standard. See page 78 (PDF page 84) of the attached PDF, which is the standards for nearly all coaxial connectors.
However, that only describes how the mating interface is sealed. (The gasket is also why there’s a defined torque for SMA, since overtightening will affect performance slightly as the gasket deforms.) An ordinary SMA connector could still allow water into the back of the connector where the shield is crimped. And of course it won’t protect the connector body itself from corrosion.
The following users thanked this post: Smoky
« Reply #11 on: December 02, 2024, 02:34:20 am »
Ha, yes less than optimal!
These need to be small diameter to fit through a hole in concrete, so I think the N types would be too big unfortunately
« Reply #12 on: December 02, 2024, 02:36:40 am »
I'll get an in-situ photo and post that.
It might help to describe the issue better.
« Reply #13 on: December 02, 2024, 02:53:27 am »
 This is a new sensor in the lab, before it's been installed.
The enclosure is IP68 and can be submerged.
There is no ingress into the enclosure, but when submerged the SMA connector corrodes and fails.
Regards
Scott
« Last Edit: December 02, 2024, 02:55:10 am by scanfor »
Offline shabaz
« Reply #14 on: December 02, 2024, 03:06:20 am »
.."non acidic" silicon rubber solution
By chance, I was looking for such a thing the other day, and I wanted it to be available in a small tube, and cheap. A low-cost, easily available option is Loctite 5660, it doesn't emit acetic acid, and, can confirm it is odorless when applying. My use-case was not under-water, so I can't comment on that.
Offline Bud
« Reply #15 on: December 02, 2024, 03:25:00 am »
Paint the connection in place with Plasti Dip, covering the crimp too.
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« Reply #16 on: December 02, 2024, 03:42:45 am »
Hot dipping in plastic.... Or silicon sealant
Making products for IOT
Offline Smoky
« Reply #17 on: December 02, 2024, 03:53:21 am »
Butyl adhesive would work very well. It's used to install windshields.
Smear it over the entire fitting after it's installed.
It remains soft and can be removed with mineral spirits.
Offline Kean
    • Kean Electronics
« Reply #18 on: December 02, 2024, 04:40:43 am »
I typically use 3m Scotch 23 Self-Amalgamating Tape to cover outdoor connectors.
Based on that photo I think you will have difficulty properly sealing it from submersion by wrapping with rubber tape.
I suggest using a generous amount of something like Sikaflex, or other neutral cure silicone.
Plastidip maybe would work, but from memory it doesn't make that tight a seal with some surfaces, so it may allow water to wick in.
Maybe you could attach the antenna cable semi-permanently before installation, and use something like that IP68 SMA boot I linked earlier to help seal the antenna end of the cable.
Offline Poroit
« Reply #19 on: December 02, 2024, 06:42:52 am »
G'day Scott,
I suggest get rid of the connector on the enclosure by using a Nylon IP68 Cable Gland and 500mm of RG58 Cable.(Pigtail)
Then fit N Type Male to Antenna Cable and N Type Female to the Pigtail.(Hopefully this won't affect your Signal Strength)
Wrap those connectors with Self Amalgamating or Denso Tape.
Your Gorilla's should be able to handle N Types.
RFI  and Rojone were always a good source in Oz.
The following users thanked this post: tooki, scanfor
Offline tooki
« Reply #20 on: December 02, 2024, 08:52:04 pm »
I was just gonna suggest almost the same thing -- use a cable gland to exit the enclosure, with enough length to relocate the antenna connector to above the water line, if the boxes don't fill up to the brim. If they do, then I'd seal the mated inline connectors using one of the methods described by others.
OP said they can't use N connectors due to size restrictions.
Offline Poroit
« Reply #21 on: December 03, 2024, 07:47:16 am »
Oops....sorry I missed that about N Types.
How about TNC Series?
Offline max-bit
« Reply #22 on: December 10, 2024, 04:35:21 pm »
SMA is basically a "delicate" connector (even in the best design).
It is much better to use a TNC connector or simply an N connector.
Offline Poroit
« Reply #23 on: December 11, 2024, 04:36:00 am »
G'day max-bit,
The OP stated that N type will not fit through the access hole in the concrete pit.
TNC may also be to large...... but we wait for response.
Offline max-bit
« Reply #24 on: December 11, 2024, 05:10:06 am »
In this case, I would use SMA but wrap it with self-vulcanizing tape.
Unless it is to be disconnected frequently...
Then good SMA and hope for luck that nothing will happen.
