I figure the reason why people are interested IS the irregular structures though, I guess I never thought about it from a "make a QSO" prospective that you have. I figured most end game would be some thing real weird, which is why I put alot of effort into these obnoxious manufacturing techniques that may have some unique capabilities if they are mastered, but its alot of stress for slow results lol
but on the other hand if you can't make standard parts its like not having good test leads for a experiment which makes it ultimately fail.
But there is another aspect to this, that is simple parts with bad aspect ratios for machining, but I guess that is not a problem unless its a serious installation
Especially with high frequencies, the connected at the end seems not achievable with machining techniques, I think there is a giant wall there, but I am seeing that there does not seem to be a good way around it, you need both machining and the 'other' techniques to be practical/high quality. The machining part is difficult to learn and time consuming but somewhat standardized and approachable, the other part is a total crap shoot
perhaps you are right that machining is the way to get some of the system running, but the other part is necessary. I am not convinced that you can get away from machining by only using the other part, but it seems like the way most people would try to do it because in theory its alot easier to plate something or what have you, but I am seeing nothing but obstacles trying it that way.
machining everything that can be machined is going to make the errors go way down, unless you truely master some exotic manufacturing methods. But, it depends on the experiment, some experiments are so insensitive (or sensitive if you think about it conversely) that it almost does not matter if your hookup is crap, and some experiments are the opposite where you won't see jack shit unless the rest of the system is NIST grade. However, given that the MMWAVE test equipment (calibration? whats that) people are likely to have are already going to be dodge city, having the best hookup possible probobly will help lol
