I'm specifically looking for a transmitter between 10.7GHz and 11.7GHz, due to my intended setup on the receiving end.
Not sure your area uses Ku band for satellite TV or not.
IF your area uses Ku band for satellite TV, do you allow to transmit in 10.7 GHz to 11.7 GHz?
I live in the US. Here, we don't have free-to-air satellite TV. In the US, satellite is all paid TV. And to avoid being able to be illegally received/pirated using standard free-to-air satellite LNBs, paid satellite TV signals are transmitted with circular polarization. Normal free-to-air satellite TV (used in some other countries) uses linear polarized LNBs. In both cases, it's in the KU band, but with different polarization, it's unlikely to interfere. Those cheap KU band LNBs you can buy on Amazon or Ebay are linear LNBs for receiving free-to-air satellite signals found elsewhere in the world, but in the US, they serve very little practical use.
However they can be used for a very cheap microwave receiver for experiments, provided that you also have a signal source that operates in the same frequency. And that's the hard part, is getting a transmitter for this frequency band. KU band LNBs typically operate in one of 2 polarizations, horizontal and vertical, which is selected by the voltage used to power the device. If you power it at 12V you get one polarization. If you power it at 18V you get polarization 90deg to what you get at 12V. This is to prevent needing to manually rotate the LNB by 90 deg to switch polarization. The frequency band is selected by the presence (or lack of presence) of a 22kHz tone. Without the tone, the KU low band is used, between about 10.7GHz and 11.7GHz. With the tone, the frequency band you get is the KU high band, between about 11.7GHz and 12.7GHz. The specs for the tone is a 1Vp-p 22kHz square wave.
For simplicity of setup, I'm not going to figure out how to inject this audio tone onto the coax. It's going to be difficult enough to build a Bias-T adapter to inject DC power on the coax, and then extract the RF off of the coax. So without the tone, I'm limited to receiving the KU low band between 10.7GHz and 11.7KHz.
Now with that in mind, I'm going to just need to figure out how to generate a microwave signal within the range of 10.7GHz and 11.7GHz, so that it will be receivable by a cheap KU band linear LNB that I can buy on Amazon.
