Quick request: could you check & post the voltages on pins 2 & 3 of connector P16 (5 pin plug to the memory unit, or behind the blanking plate on the rear panel if no memory unit fitted)? And post the first couple of characters (build date) of the serial number?
According to the all the manuals it should be 11v on pin 2 & 13.5v unregulated on pin 3 (pin 5 is gnd), but the couple I've checked have that reversed. Curious minds want to know...
The manual is wrong - mine is 14.7 on P2 and 10.3 on P3
Magic - thanks for confirming that!
(Some of the FRG-7700 fan-folk around the traps are a little ... let's say "odd". A friend of mine once asked the same question on a couple of Ham/SWL groups/mailing lists and ended up with a huge argument from non-technical people who swore black & blue that the manual was right and he was wrong, stupid, and that the sets we'd checked had obviously been tampered with...)
edit: the 14.7v is OK - it's unregulated, and basically only feeds the audio amp and a few zener regulators around the circuit - but the 10.3v is a bit low (should be closer to the regulated 11v).
The SN is a little confusing.
SN on the outside is: 1I110212. On this sticker the first two symbols - the "1I" is stamped with a little different ink than the rest of the number.
SN on the inside sticker is: 110212
EDIT: Oh wait there is a SN on the memory unit too. It's P1J070766
Ta. "1"=1981, "I"=September & "J"=October. It also indicates that it was assembled in the factory without a memory unit (no "M" prefix on the set), and the memory unit was added later ("P" prefix - presumably for "part" - on the memory unit). Probably as a dealer/distributor add-on, since the dates are so close.
FWIW, the other sets we'd seen were also 1981 builds (my own is 1I, and I think his was 1H), so I wouldn't swear that bit of the manual is wrong for all sets - but it certainly seems it is for late 1981 builds. And good to know it's also the case for sets with memory units, since none of the ones we'd checked had them fitted.
The
reason I asked - I worked with a friend on that, and have inherited it completely after he passed away.
