Author Topic: when earth is not earth  (Read 2256 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: October 31, 2022, 09:12:24 pm »
I was messing with my least favourite project in the office today. Something designed by a subby that I now need to get through EMC, well its power supply actually.
So the cabling we use has a shield, it's that industrial grade mains cable, it's steel. So I have taken advantage of this and connected it to the metal box the power supply is in. I made a mock up of the actual machine with a die cast box with resistors in it to load the supply with a "non reactive" load.
I used a near field probe and was surprised to find stuff coming off the shield at various frequencies, around 110MHz and various spots I had not noticed before as it is usually around 70MHz (I've been messing with it for a while). Then as I was doing some narrower band measurements my boss was changing the lights and I could see the signal literally going up and down to the banging he was doing (getting those horrible grills off office ceiling lights). Then I pointed the probe in the direction of the light fitting above me, I noticed some very slight bumps in exactly the same place.....
So it seems that i am picking up noise from the lights from cable screening on a power lead plugged into a socket.
This leads me to wonder as to what is the best way to separate myself from such earth interferences. Should I have a dedicated earth, or put some sort of filter in place? the spectrum analyser and the power supply were plugged into the same socket bar, so I seem pretty doomed.
Offline Geoff-AU
Re: when earth is not earth
« Reply #1 on: November 01, 2022, 05:57:19 am »
A LISN will help isolate power-borne noise, they're used for making conducted EMC measurements.  But normally you're only doing conducted up to 30MHz and radiated above that.  You might need some lighting that doesn't come from Alibaba :)  If it's radiating in then it'll be a pain in the butt.
Offline Simon
  • Global Moderator
« Reply #2 on: November 01, 2022, 07:57:00 am »
I looked at LISN's but they only ever show a live and neutral, I would expect then that the earth just passes through. Just the same as all CMC you get off the shelf.
I'll probably have to go back up to my semi faraday cage area where at least there are no lights and I am on a completely separate circuit.
Offline jonpaul
« Reply #3 on: November 01, 2022, 08:40:06 am »
Suggest you read the classic Noise Reduction by Henry Ott
See SYNAUD COM for many audio interference and shieldiing, earthing practices.
Bon courage
Jon
PS said in 1971...
"there is NO such thing as a ground"
By The late and great Dick Sequerra,
RF and hifi pioneer, ex Marantz
Jon
Jean-Paul (EE 1968, the Internet Dinosaur)
The following users thanked this post: pardo-bsso
Offline tggzzz
« Reply #4 on: November 01, 2022, 09:21:36 am »
PS said in 1971...
Precisely.
"Ground" or "earth" is a fiction, one that is convenient in some circumstances.
Common example: cheap mains checkers verify that the three connections are correct and that the "earth resistance" is OK. Daughter's house shows green, my house shows orange, parent's house showed red (despite, according to the current owner, it having a three phase supply!).
Extreme example: when caught out in a thunderstorm. One of the recommendations is not to stand with feet apart, but keep your feet together. The reason is that if there is a nearby strike to the ground, there will be a lot of current going through the ground; you would prefer that the easiest path is through the ground between your feet, not through your body between your feet.
Offline 2N3055
  • Country: hr
« Reply #5 on: November 01, 2022, 09:39:12 am »
I wonder what would they call it when on Mars or Moon....  :-DD
Offline tggzzz
« Reply #6 on: November 01, 2022, 10:59:11 am »
The earth and moon do form a capacitor. Which side is the ground?
Offline Wallace Gasiewicz
« Reply #7 on: November 01, 2022, 11:16:59 am »
I suppose you are talking about fluorescent lighting. I do not know what sort of "starter" your lamps use.
A friend of mine who is an electrician, used the smaller ballasts many years ago in his hobby radio shop. The new small ballasts were the "thing" when he put them in.
The interference given off by the florescent was so great, he could not tune even Ham radios without trouble.
Turning off the lights stopped the interference, but working in the dark was a problem  HA!
All lighting does give some "interference" but florescent appear to be the worst of the commonly used lights.
Online nctnico
« Reply #8 on: November 01, 2022, 01:00:37 pm »
Still, a LISN can be used up to 100MHz or so. Still helpfull to see what current goes into a cable.
Offline themadhippy
« Reply #9 on: November 01, 2022, 01:48:39 pm »
There is no earth side of the moon,as a matter of fact its all moon.
The following users thanked this post: Geoff-AU
Offline radiolistener
  • Country: ua
« Reply #10 on: November 01, 2022, 06:07:36 pm »
Offline Grandchuck
« Reply #11 on: November 01, 2022, 06:32:16 pm »
If you scroll through the pictures you will find one that seems to have dirt in it ... is that the ground?
Offline Simon
  • Global Moderator
« Reply #12 on: November 01, 2022, 10:08:14 pm »
Offline Henrik_V
  • “ground” is a convenient fantasy
« Reply #13 on: November 02, 2022, 09:33:24 am »
This lab ground could be lifted to higher potential :D
« Last Edit: November 02, 2022, 09:35:26 am by Henrik_V »
Greetings from Germany
Henrik
The number you have dialed is imaginary, please turn your phone 90° and dial again!
« Reply #14 on: November 03, 2022, 12:07:13 am »
It is commonly believed that the earth is negatively charged.
This must be true looking at the current events happening all around us.
Offline antenna
« Reply #15 on: November 03, 2022, 02:04:59 am »
Just found a used copy of the second edition for $35!  I'm going to need a bigger book shelf soon.
Offline Geoff-AU
« Reply #16 on: November 03, 2022, 03:56:34 am »
I sure hope that's been calibrated recently.
Offline coppercone2
« Reply #17 on: November 03, 2022, 04:21:19 am »
i would not trust that at amazon
Offline antenna
« Reply #18 on: November 03, 2022, 05:04:06 am »
It was listed as used but having no pages missing..
Offline antenna
« Reply #19 on: November 09, 2022, 06:29:52 am »
Just figured it was worth the update.  It wasn't a scam, thankfully. It had some bent pages, but thats all that was wrong with it.  No writing, no highlighter, no missing pages, no binding damage, only one little sticker. Really nice book!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #20 on: November 09, 2022, 08:58:18 am »
Having a hardcopy is good, less eye strain and no need to flip a switch. For those who less fortunate can usually find a softcopy from a legit net https://commons.princeton.edu/motorcycledesign/wp-content/uploads/sites/70/2019/08/otto_1988_noisereduction.pdf
The following users thanked this post: Andy Watson, Bud, theHWcave, mag_therm, Krudler
« Reply #21 on: November 28, 2022, 05:47:35 pm »
OK I cannot resist:
A fellow goes into a Starbucks and gets a coffee. It is terrible. He tells the counter person that "This coffee tastes like MUD!!!"
Starbucks Barista replies:  Funny, It was just GROUND this morning!
The following users thanked this post: nctnico, KK6IL, mawyatt
