To be fair, a lot of CB radios were built on exactly the same PCB material as a lot of Ham radio and even PMR radios of the time, the difference was generally in the quality of the design and components, modern CB stuff is SMD for the most part and is on far better quality fibreglass using, mostly, much better quality components.
I think the main reason for their being built 'upside down' was everything to do with the speaker, if it were for mechanical reasons then car radios would have been built that way round too and my memory tells me there was a mix of both even from the same manufacturer so I'd suspect the orientation of the board in car audio is chosen purely for mechanical/manufacturing convenience.
And that Sommerkamp, yes, most desirable but what a pig to work on, nightmare delicate connections to the LED frequency counter display as I recall but a lovely PLL design. The Belcom LS102 was similar.
