Industrial temperature ranges and Wifi makes very little sense to me. One expects a highly demanding, high reliability environment, where a connection loss could be damaging. The other, where connection is optional, with unreliable wifi.
How do you even power your device? Do you already have a battery wich is rated to 105C? If so, then the cost of the wifi chip is the least of youf concern. And if you power the device through a cable, why do you need wifi in the first place?
Automotive is different, because the infotainment systems usually have much worse rating than the rest of the car.
