When I read the reviews of the SDRPlay it scored as well as 300$ models and seemed like it had a really good adc with 12 bits of sampling.
It has very bad ADC, which parameters can be compared with 7-bit ADC.
SDRPlay is overpriced. This is more marketing product.
It has 12 bit ADC, but it's performance is even worse than 8-bit ADC of RTLSDR. SDRPlay and RTLSDR have almost the same performance in average. SDRPlay is a little less sensitive to strong signal, but has a little worse IMD than RTLSDR. SDRPlay has less sensitivity and more gaps in frequency coverage. Also SDRPlay has 8 MHz bandwidth against RTLSDR 3.2 MHz. Wide bandwidth helps to see wider frequency span on the waterfall, but this is not required for radio listening.
The bad thing with SDRPlay is that it has worse NCO noises than RTLSDR. Also it has terrible gain control in comparison with RTLSDR.
If you try to compare SDRPlay with fair 12-bit ADC receiver, you will find a huge (very huge!) difference. When you can see that difference you will realize that the real SDRPlay performance is the same as RTLSDR and even sometimes worse. They trying fix it by adding filters and amplifiers on the input, but you can do the same with RTLSDR. You cannot fix bad dynamic range and bad IMD performance with filters and gain tweaks.
The good SDR receiver with high dynamic range don't needs filters on the input (at least cheap like used in SDRPlay), because they cannot improve something and just add losses.
TVdongles don't even work below 30 mgh but that makes sense as there is no tv down there..
Regarding to short wave, RTLSDRv3 works very well from 100 kHz to 30 MHz, I compared it with SDRPlay and didn't find any difference. With RTLSDRv3 you can see and receive all short wave stations that you can see and receive with SDRPlay. But SDRPlay has more dead frequencies and spurs which are missing on RTLSDRv3.
Here is comparison for SDRPlay and RTLSDR tv dongle, both are working simultaneously on short wave (1413 kHz).
Do you see any advantage against RTLSDR? And this RTLSDR tv dongle cost just 21 usd
So, don't believe to that marketing stuff. You can do the same with RTLSDRv3 dongle for less price and even with better quality
If you want better SDR quality, try Hermes Lite 2. It's price about 200-300 usd. But it has much better performance.
