I'm going to expose my ignorance here, but what the heck. I've been reading a lot of reviews of portable Shortwave & AM (medium wave) radios recently and regarding the AM band, a frequent comment is that the loopsticks (ferrite coils) are small/short, causing sub-par medium wave performance.
I've read that the iron core inside the coil can even extend way longer than the edges of the coil itself and can help with sensitivity. Or even if the iron core didn't extend past the sides of the coil, it would still help if the entire loopstick was longer.
So ignoring the existence of antenna boosters and mutual coupling and all that (to keep this simple), my question is - Why does a longer coil and/or longer iron core inside the coil increase sensitivity? The loopstick is in effect the antenna. If I'm remembering correctly, a larger core would increase inductance (more magnetic permeability). But why would a greater inductance help with sensitivity? Whether you have a radio with a large or small loopstick, you're tuning the same signal so I'm assuming the inductance would need to be the same. And if you did want greater inductance, if you wanted a different way to fit a very small coil inside a portable radio, couldn't you also increase inductance by increasing the number of turns? I also wondered if a larger coil or core might simply capture (due to surface area) more of the signal but when a radio with a 3.85" loopstick has a much better sensitivity than a radio with a 2.69" loopstick that doesn't add up to me (seems like such a small difference wouldn't help much).
Anyway, just want to better understand the whole topic. Thanks!
