Ok, folks, I see that I was short in details and I'll need to expand the issue a bit
Let me start by thanking all of you for the replies, but now, let me explain the "issue" with more details, the point is the following, I and another folks designed and tested an RX ONLY antenna, the points for the design were:
* Good coverage of HF bands
* Good impedance match over the covered range to allow using whatever preamp/other
* Somewhat better characteristics than existing small antennas (still a compromise, but that can't be avoided)
* Ease of build, by using commercially available components and "no soldering" or stuff which "normal people" can't do
* Fit in most location due to small size and not heavy dependence on ground
the result was this critter which we (I and 13dka) called the "SULA" antenna (Small Unidirectional Loop Antenna)
https://swling.net/viewtopic.php?t=55such an antenna allows to cover 1 to 30 MHz (at least) with an horizontal cardioid pattern and quite good vertical angles, and while testing it we found that it exceeded expectations (remember it's a RECEIVE ONLY antenna, not designed for TX) offering a coverage extending from MW up to about 100MHz and then from about 200MHz up to 500MHz (although up there the pattern is reversed)
After a bunch of NEC modeling/simulations and field tests, we came out with the final design shown at the above URL (and NO, routing the wire "inside" the loop instead of having it "dangle" isn't a good idea, since it will ruin the pattern), the idea then was to find some commercially available (and CHEAP) components which could allow anyone to test the antenna with little effort, for a start, we used the
NooElec 9:1 v2 BalUn and the
NooElec LANA HF barebones preamplifier, not because we "particularly love NooElec", just since both units were cheap and easily available worldwide (even on amazon), anyhow, getting back on the reason for my request
I'm trying to find a widely/easily (and relatively cheap, see the NooElec prices) LNA unit for that antenna, the
SV1AFN unit has already been tested with dismal performance, so we're back seeking for a suitable LNA unit; notice that the antenna is not and won't be (at least NOT from me) some commercial thing, that's not the purpose at all
So... any suggestion
P.S.: by the way, if you want to give the "SULA" a spin, it will be really interesting, here's an example of what it can do (using the NooElec BalUn and LNA)
(if someone is curious, the TL;DR whole story of the development can be found
here - excluding "some" private mails/messages, that is
[edit]
for the interested ones, here are the SWR/Impedance/Gain curves (note that it's all about SNR and directivity, it's an RX antenna)
