Author Topic: Wideband RF power amplifier  (Read 1434 times)
Offline stenborgTopic starter
« on: December 07, 2023, 05:39:08 pm »
I have bought an amplifier on an auction that I need some help with. It is built by RF power labs, a company that doesn't exist anymore. And Google doesn't say much either.
My tests so far concludes that it at least works and gives output. Someone said I could expect 5-10W output power. My intention is to use it for immunity testing in a TEM cell.
I've attaches some photos.
Questions:
1. Have anyone seen this before? And if so have any documentation.
2. I have swept it from 1-500MHz with a -10dBm signal (0dBm seemed to overdrive it). The output is very nonlinear with peek power around 65MHz. Is this expected?
3. A sticker says 0.5-1000MHz What could be the expected band width with this construction?
4. Any further information that could be helpful.
Thanks
Per-Ola
Offline pienari
Re: Wideband RF power amplifier
« Reply #1 on: December 07, 2023, 05:58:30 pm »
I can not see what fets is in the board?.
« Reply #2 on: December 07, 2023, 08:28:54 pm »
All are POLYFETs. The FET in the final stage is a F2012 and in the 2nd stage it is aF2001. 1st stage is hard to read but begins with F200.
Offline jonpaul
« Reply #3 on: December 07, 2023, 09:05:30 pm »
like many CATV line amps. Millions were made.
Most like a 72 or 75 Ohm Zo.
Jon
Jean-Paul  the Internet Dinosaur
Offline tszaboo
« Reply #4 on: December 07, 2023, 09:07:51 pm »
Jon
Those are clearly 50 Ohm BNC connectors.
Offline jonpaul
« Reply #5 on: December 08, 2023, 12:01:26 pm »
BNC type connectors exist in BOTH 50 and 75 Ohm versions.
Broadcast equipment has many 75 Ohm BNC, with slightly different inner conductor dim.
Eg used for Composite FM FMCX digital audio or AES2id.
 What is measured Zo 50 or 75 Ohm?
Jon
Offline tszaboo
« Reply #6 on: December 08, 2023, 12:12:36 pm »
The isolation is also different for 50 and 75 ohm. This looks like 50 ohm( middle row)
« Reply #7 on: December 08, 2023, 03:03:41 pm »
thanks for helping me understand this amplifier. Regarding the impedance. What speaks for 50ohm is the company that used it before, I can hardly think why the could have the use for a 75ohm amp. But connecting its input to my VNA isn't conclusive, see attachment. It's all over the place, but at least centered around 50ohms. Maybe a 6dB attenuator on the input would be wise.
But at least the datasheet for the F2012 confirms the 5-10W expected power.
Keep up the good work!
/Per-Ola
