Now I'm just getting a big fat finger on a simple upgrade.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif.pagespeed.ce.8iLbFYV4Bc.gif)
pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list
pi@raspberrypi:~ $ sudo apt update
Get:1
http://mirrordirector.raspbian.org bookworm InRelease [15.0 kB]
Hit
http://archive.raspberrypi.org jessie InRelease
Hit
http://archive.raspberrypi.org jessie/main armhf Packages
Get:2
http://mirrordirector.raspbian.org bookworm/main armhf Packages [14.5 MB]
Hit
http://archive.raspberrypi.org jessie/ui armhf Packages
Ign
http://archive.raspberrypi.org jessie/main Translation-en
Ign
http://archive.raspberrypi.org jessie/ui Translation-en
Get:3
http://mirrordirector.raspbian.org bookworm/contrib armhf Packages [62.3 kB]
Get:4
http://mirrordirector.raspbian.org bookworm/non-free armhf Packages [118 kB]
Get:5
http://mirrordirector.raspbian.org bookworm/rpi armhf Packages [1360 B]
Ign
http://mirrordirector.raspbian.org bookworm/contrib Translation-en
Ign
http://mirrordirector.raspbian.org bookworm/main Translation-en
Ign
http://mirrordirector.raspbian.org bookworm/non-free Translation-en
Ign
http://mirrordirector.raspbian.org bookworm/rpi Translation-en
Fetched 14.7 MB in 26s (562 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
872 packages can be upgraded. Run 'apt list --upgradable' to see them.
pi@raspberrypi:~ $ sudo apt upgrade
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libc6-dbg : Depends: libc6 (= 2.19-18+deb8u7) but 2.31-13+rpi1+deb11u8 is installed
libc6-dev : Depends: libnsl-dev but it is not installed
libcrypt-dev : Breaks: manpages-dev (< 5.01-1) but 3.74-1 is installed
libnih1 : Depends: libc6 (< 2.20) but 2.31-13+rpi1+deb11u8 is installed
manpages : Breaks: manpages-dev (< 5.09-2) but 3.74-1 is installed
openssh-sftp-server : Depends: openssh-client (= 1:6.7p1-5+deb8u3) but 1:8.4p1-5+deb11u3 is installed
wsjtx : Depends: libgfortran5 (>= 8.3) but it is not installed or
libgfortran4 (>= 7.3) but it is not installed or
libgfortran3 (>= 6.3) but 4.9.2-10 is installed
Depends: libgomp1 (>= 6) but 4.9.2-10 is installed
Depends: libqt5serialport5 (>= 5.7) but it is not installed
Depends: libqt5multimedia5-plugins (>= 5.7) but it is not installed
Depends: libqt5widgets5 (>= 5.7) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libqt5network5 (>= 5.7) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libqt5printsupport5 (>= 5.7) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libqt5sql5-sqlite (>= 5.7) but it is not installed
Depends: libboost-log1.62.0 (>= 1.62.0) but it is not installable or
libboost-log1.65.1 (>= 1.65.1) but it is not installable or
libboost-log1.67.0 (>= 1.67.0) but it is not installable or
libboost-log1.71.0 (>= 1.71.0) but it is not installable or
libboost-log1.74.0 (>= 1.74.0) but it is not installed
Depends: libboost-filesystem1.74.0 (>= 1.74.0) but it is not installed
Depends: libboost-log1.74.0 (>= 1.74.0) but it is not installed
Depends: libboost-thread1.74.0 (>= 1.74.0) but it is not installed
Depends: libfftw3-single3 (>= 3.3.5) but 3.3.4-2+rvt is installed
Depends: libgfortran5 (>= 10) but it is not installed
Depends: libqt5core5a (>= 5.15.1) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libqt5gui5 (>= 5.14.1) but 5.3.2+dfsg-4+rpi1 is installed or
libqt5gui5-gles (>= 5.14.1) but it is not installed
Depends: libqt5multimedia5 (>= 5.6.0~beta) but it is not installed
Depends: libqt5network5 (>= 5.15.1) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libqt5serialport5 (>= 5.6.0) but it is not installed
Depends: libqt5sql5 (>= 5.10.0) but it is not installed
Depends: libqt5widgets5 (>= 5.15.1) but 5.3.2+dfsg-4+rpi1 is installed
Depends: libstdc++6 (>= 7) but 4.9.2-10 is installed
E: Unmet dependencies. Try using -f.
pi@raspberrypi:~ $ sudo apt upgrade -f
Correcting dependencies... failed.
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Ign
Ign
Ign
Ign
Ign
Ign
pi@raspberrypi:~ $ sudo apt --fix-broken install
pi@raspberrypi:~ $
