In the website I linked, https://www.qsl.net/dk7zb/6m/212.htm
DE impedances of 12.5, 18.0 & 28.0 Ohms are referred to, (with matching methods described)
That is very much proof of a good amateur. Low impedance ideas are however somewhat misunderstood.
He must have tried to proof his ideas? He must have done basic measurements? No, nothing at all. That is not what HAM do.
His narrow band VSWR ideas are said less correct by this HAM:
https://www.g0ksc.co.uk/intro-lfa.htmlHe is offering a better antenna design.
So which fanclub to belong to?
None of them have provided any facts, no calculations and no source references which else is required in any fact based technology. Why doing exceptions from EM wave technology?
We can only trust their words that their home-cooked theories are the correct one.
They have probably never bothered to read about EM theory and do not even know any entry books in this field.
A RF engineers do often have within an arm-length at least one or two books written by names such as Balanis, Kraus, Stutzman and Thiele.
Such books are often a bit heavy as intention is that you should build your own knowledge based on fact and references all the way down to Hertz and Maxwell.
Such books contains very few precalculated recipes of antennas in opposite to HAM pages.
Someone knowing difference of facts relative opinions do probably not have much in common in a group where most not understand difference between rumors and fact.
It is maybe the reason that very few active HAM have any real RF skills.
all a far cry from approx 73.0 Ohms for a dipole in free space.
An ideal resonant dipole at free space have an impedance of 73 + j42.5 Ohm. If never learnt from school about complex numbers or that impedance is a complex value can it be hard to understand why both number parts are equally important when calculating a dipole. An ideal dipole can also be said have an impedance of 84 Ohm at an angel of +30° if you prefer to express it as a vector.
Exception are for HAM's, they are orienting with ease in a 2D projection using numbers for just one of the axes.
The reason I was thinking the impedance change might not be very large is because often the coupled elements resonating at the same frequency can have that effect, and I thought that the distance between elements was also a fixed fraction of a wavelength (as I said - not designed any yagi-uda antennas myself).
Yes you is correct. It is a common thing also for a lot of other kinds of waves such as sound and mechanical resonances...
For good reasons are often a Yagi-Uda antenna also called
Yagi-Uda array (note that first letter in names and terms is many languages are uppercase).
A Yagi-Uda array is an array of dipoles where the passive dipoles are parasitic elements with no feedings point making it relative simple to calculate how they affect each other and the feed element. They affect each other by
mutual impedance.
By measuring impedance of a feed dipole while adjusting distance to a passive shortcut dipole of same length can this effect be studied and it is easy to find if there are any "golden" distances where the elements not affect of each other. Directors for a Yagi-Uda are usually shorter then feed dipole and reflectors longer, but it is no absolute rule and it is not important for below shown measurements.
One of the golden distances between these dipoles as you probably already have guessed is lambda/2 and its multiples. Two dipoles at that distance and equally oriented will be blind to each other.
There are also other distances of interest. A Yagi-Uda antenna have a typical distance between each element in the range of 0.1-0.25 lambda. 0.1 lambda is a bit special distance. A shortcut dipole at that distance will not affect feed dipole resistance, but it is the distance for maximum mutual reactance.
I have done some simple measurements shown in curves below to show these effects relattive dipole distances. Measured object is a dipole with its shape adjusted to become a very ideal 50 Ohm resistive load with almost no reactance over a relative wide frequency range. Its actual impedance is not that important for below shown result but gives a simpler reference to see how another element, a shortcut dipole, at different distances affect measured impedance.
Measured antenna is center tuned at 2440 MHz
[attachimg=2]
This curve shows resistance part of impedance. Yellow curve is free space. It is when dipole have no objects in its nearfield. Green is with distance lambda/2 between the dipoles which within a reasonable bandwidth shows same resistance. It is not exactly same curve but that is a result of that measurement not is done in any anechoic chamber. Measurements are done 200 mm above my lab bench.
Blue curve, distance lambda/4 is distance resulting in maximal mutual resistance at resonance frequency.
As can be seen from this curve, if an antenna is placed near a conductive surface can it result in an increased resistance.
Reducing antenna distance relative another surface is not automatically causing an reduced resistance. In this case is it actual distance relative wavelength that is determining factor.
Red curve is a bit special, it does not affect resistance at center frequency but is rather tilted within resonance frequency range. Its distance is around 0.1 lambda, a common element distance for Yagi-Uda antennas.
Mutual reactance is just as important as mutual resistance to understand when designing an Yagi-Uda antenna but as written before, it is a bit to complicated factor to handle for many amateurs but it is still just as important factor as resistance.
Mutual reactance do however behave different then mutual resistance when distance between two dipoles varies as can be seen below.
Exactly same measurements as above, but now is it reactance part that is shown.
[attachimg=3]
Green curve is a bit low but that is due to measurement limitations. Ideal should it also here be same as curve for free space.
In opposite to resitive curve where blue curve showed max mutual resistance is mutual reactance just minor affected.
It is red curve that represents max mutual reactance. It is when dipole elements was at typical "Yagi-Uda distance".
If a Yagi-Uda antenna consist of many elements is it of course a mutual impedance between all elements. Here plays also reactance part an important role. It is much same as when designing a bandpass filter with a number of capacitors and inductors. Right length and place for each element will play an important role for total antenna performance.
Playing with reactance for each element is mainly y adjusting element length. To balance high mutual inductance is director element slightly shorter then lambda/2 used, which causes them to be a bit capacitive.
Same measurement as above but represented by its impedance. can be seen in curve below. Table is for yellow curve in free space.
[attachimg=1]
Shown antenna behavior and mutual impedance is typical but not exact repeatable.
Result is depending on a lot of details, including standing waves relative a roll of solder in opposite end of my labbench.
Above measured dipole is rater wide band relative an ideal dipole as can be seen in the curves. According to some HAM logic should that be negative for antenna efficiency due to low Q.
Antenna efficiency expressed in percent is max 100%. Higher is not possible as an antenna is a passive structure.
For that reason can it be interesting to see measured antenna efficiency for this dipole in free space:
[attachimg=4]
Not mentioned regarding these mutual effects is if element affecting the dipole not is a good conductor. Soil below antenna is a often poor conductor. A mix of reflector and absorber.
An antenna above ground, especial if soil below antenna is wet can it be very absorbing. Absorbing soil act as a variable atenuator for the antenna.
Commersial shortwave radio with real long horizontal dipoles, a few MHz or lower, do often place a metal net at ground below antenna to avoid atenuator effect of antenna. Ground do then become a reflector instead of absorber and total radiated power increases.
Not neither mentioned is if there are more then two dipole elements which often is the case for Yagi-Uda antennas. All elements will affects each other. Not really any complicated then already shown above but it will be more terms in calculations of complex impedances.
Actually is it a lot of other things not either mentioned but it is still at a very basic level. It is better to read a good RF theory entry book from any of above mentioned authors then trust me, as I may be wrong and is definitive incomplete. There are much more to learn. A book that starts from almost zero assumed knowledge is
"Antenna theory" by Balanis.
