Author Topic: Putty/FileZilla - Keygen Vuln  (Read 207 times)
Offline bingo600Topic starter
« on: April 16, 2024, 04:16:30 am »
Not likely to be  a "bad one" , unless you are commting to git etc. with Putty.
But do update your Putty, FileZilla etc ...
https://www.cvedetails.com/cve/CVE-2024-31497/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2024-31497
All NIST P-521 client keys used with PuTTY must be considered compromised, given that the attack can be carried out even after the root cause has been fixed in the source code (assuming that ~60 pre-patch signatures are available to an adversary).
### Mitigations
This vulnerability has been fixed in PuTTY 0.81, FileZilla 3.67.0, WinSCP 6.3.3, and TortoiseGit 2.15.0.1. Users of TortoiseSVN are advised to configure TortoiseSVN to use Plink from the latest PuTTY 0.81 release when accessing a SVN repository via SSH until a patch becomes available.
The following users thanked this post: Halcyon
Offline Halcyon
  • Global Moderator
Re: Putty/FileZilla - Keygen Vuln
« Reply #1 on: April 16, 2024, 04:58:48 am »
Revoke and regenerate keys on the server end as well.
