Author Topic: USB stick, encrypted, no keypad or software to install, how?  (Read 241 times)
Online Simon
  • Global Moderator
    • Simon's Electronics
« on: January 11, 2020, 03:55:53 pm »
https://www.ebuyer.com/582747-kingston-datatraveler-32gb-encrypted-usb-3-flash-drive-ebuyer-com-dtvp30-32gb
So i see a claim that you do not have to install software and i cannot see how one enters any code as there is no keypad. Anyone with more information on these than the manufacturer is willing to share?
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Online Bud
Re: USB stick, encrypted, no keypad or software to install, how?
« Reply #1 on: January 11, 2020, 05:00:32 pm »
I recall you get a pop up dialog when you insert it , where you enter the password. Or it installs as a drive but all you see is a  small executable that you have to run and enter the password, then you can see rest of data. Cant remember exactly, i had a 16 GB one some years ago.
Online Simon
  • Global Moderator
« Reply #2 on: January 12, 2020, 09:29:12 am »
Ah right, that's why it's not Linux compatible. I kind of like the idea but wanted to give linux a go again at some stage so I am torn.
Offline jc101
« Reply #3 on: January 12, 2020, 08:36:34 pm »
If the Kingston part is correctly listed on the eBuyer link, then it can be used on Linux - according to the data sheet https://www.kingston.com/datasheets/dtvp30_en.pdf
I think there will be a Linux mountable image on the small partition, or the software can be downloaded from Kingston.
Online Simon
  • Global Moderator
« Reply #4 on: January 12, 2020, 08:55:08 pm »
Well I'm not using linux any time soon and i only need 4GB to hold the private data like passwords. I've ordered a 256GB for general data that is not sensitive.
Offline Whales
    • Halestrom
« Reply #5 on: January 12, 2020, 09:05:53 pm »
N.B. you can make something equivalent up using other software.  Just leave it sitting on the drive.  This also lets you transfer your stuff from one drive to another without having to worry about finding the same model+vendor of flash drive again.
On Linux I find encfs very convenient, as you only need a folder (not a partition) for storing your encrypted stuff.  Looks like there is a Windows port.
There's also the traditional Veracrypt, likely much more popular but it has been years since I used its predecessor.
Online Simon
  • Global Moderator
« Reply #6 on: January 12, 2020, 09:10:09 pm »
I just want something to work. For £19 I'm happy. I'd rather not encrypt everything anyway. been theere done that got the medal for lost data thank to microsoft.
Online Bud
« Reply #7 on: January 13, 2020, 01:17:42 am »
Hmm... Found mine and it does have a folder called linux. This is how it looks as you plug the stick in to Windows
Offline Whales
    • Halestrom
« Reply #8 on: January 13, 2020, 08:31:53 pm »
Ooh, can you show what's inside the folder?
