Products => Computers => Security => Topic started by: Ed.Kloonk on November 30, 2021, 09:54:36 am
What do you think?
https://odysee.com/@seytonic:c/i-made-a-usb-stick-that-detects-wifi:b (https://odysee.com/@seytonic:c/i-made-a-usb-stick-that-detects-wifi:b)
https://www.youtube.com/watch?v=NMY4iSMF2CU (https://www.youtube.com/watch?v=NMY4iSMF2CU)
It is an USB WiFi dongle, which also provides information (probably using a separate USB endpoint) whenever it receives (or sends) a WiFi deauth frame.
In Linux (including OpenWRT-based routers), that functionality could simply be added to wpa_supplicant (https://w1.fi/cgit/hostap/tree/wpa_supplicant) (if not already added, I haven't checked). Basically, it's only a little bit of additional code to the deauthentication code path.
