Author Topic: [solved] Where from comes this user "message+"?  (Read 3979 times)
Online RoGeorgeTopic starter
« on: June 29, 2021, 09:19:13 am »
When I run 'top' I see a user "message+" running dbus-daemon.  This pops in and out shortly at each 2-3 seconds.  I don't recall seeing it before.  Googled and couldn't find any answers.
Anybody knows where this user message+ comes from, or what to run to find out more about it?
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
   1499 message+  20   0    8884   5824   3904 S   0.3   0.0   0:16.91 dbus-daemon
OS Kubuntu 20.04 LTS.
« Last Edit: June 29, 2021, 10:20:37 am by RoGeorge »
Offline sleemanj
  • Professional tightwad.
Re: Where from comes this user "message+"?
« Reply #1 on: June 29, 2021, 09:48:37 am »
I expect that "+" means that it's truncated for display space, and that this is the "messagebus" user.
Offline bitwelder
« Reply #2 on: June 29, 2021, 09:57:28 am »
To show a longer field for the username you can use a custom format for the 'ps' command, e.g.:
ps ax o user:16,pid,pcpu,pmem,vsz,rss,stat,start_time,time,cmd
« Reply #3 on: June 29, 2021, 10:19:49 am »
Message+ is messagebus indeed, thank you!   :)
ps ax o user:16,pid,pcpu,pmem,vsz,rss,stat,start_time,time,cmd | grep message
messagebus          1499  0.1  0.0   9016  5860 Ss   08:47 00:00:23 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
