Author Topic: OP amps basics  (Read 3146 times)
Offline PbFootTopic starter
OP amps basics
« on: December 28, 2012, 04:28:07 pm »
I'd like a blog on op-amp basics. A good basic topic, with lots of applications.
-PbFoot
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: OP amps basics
« Reply #1 on: December 28, 2012, 04:29:30 pm »
I'd rather see a blog on the more advanced uses, opamp basics are well documented in books etc but they have so many uses it would be good to see the more exotic uses.
Offline xDR1TeK
  • Country: lb
Re: OP amps basics
« Reply #2 on: December 28, 2012, 04:43:00 pm »
ESPECIALLY, single supply shift from dual supply.
or for example, removing an opamp and replacing it with raw class type amp.
Limiters that can operate on opamps.
I will revisit here and add ideas.
and will never do. life goes on...
« Last Edit: April 26, 2014, 08:07:47 pm by xDR1TeK »
Offline kyle
Re: OP amps basics
« Reply #3 on: April 20, 2013, 01:19:23 am »
I 2nd this, video on op-amps for beginners would be very helpful.
Learning slowly.
Offline amspire
Re: OP amps basics
« Reply #4 on: April 20, 2013, 01:40:38 am »
The free 1200 page book from Analog Devices "Basic Linear Design" by Frank Zumbahlen is almost an essential download for anyone wanting to learn or use opamps.
This suggestion came from Chris on one of the Amp Hour podcasts. A great book. Chris said you could buy the dead tree version pretty cheaply as well.
http://www.foxcomputer.se/Basic%20Linear%20Design.pdf
Offline olsenn
Re: OP amps basics
« Reply #5 on: April 20, 2013, 02:30:57 am »
Check out "Op-Amps For Everyone" (http://www.ti.com/lit/an/slod006b/slod006b.pdf) and buy the full updated book: http://www.amazon.com/Op-Amps-Everyone-Third-Edition/dp/1856175057/ref=pd_sim_sbs_b_3 (Go for the 3rd Edition, not the 4th)
