Author Topic: Trace repair video - Lisa followup.  (Read 2618 times)
Offline gildasd
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
« on: December 25, 2014, 11:06:16 am »
Hi
Following your crusty Apple Lisa tear-down.
In this tear-down, some the slot connector pads that are badly corroded, a few to the point of not being "there" anymore.
I work in a marine environment, the equipment is protected, but I'm sure I'll get this one day, and it will on a critical piece of kit, 2000miles and 3 weeks from the nearest place where I can get a replacement sent.
Our stuff is not supposed to fail, but even the best stuff sometimes has problems.
It would be interesting to have a video in two parts:
- Repairing "properly" for the aficionado of fine vintage electronics.
- Bodging that will last until a spare can be found for the professional...
I am in no way saying that you must do a full repair on the Lisa, that's madness, doing one pad with each technique is sufficient.
Just to know the basics to be the "holy electronics saviour" onboard :)
- How to.
- What parts/products need to have in my personal toolkit.
Still a student, that's why I don't give you any money for all your fine work - yet.
Merry Sun-cream holidays!
G
I'm electronically illiterate
Offline miguelvp
Re: Trace repair video - Lisa followup.
« Reply #1 on: December 25, 2014, 07:29:30 pm »
Search on youtube for user paceworldwide
It has not just soldering tutorials but also board repair, and some silly adventure clips as well for repairing a board that will save civilization or something like that.
They are old but very informative.
Edit: found them
https://www.youtube.com/user/paceworldwide
look at the rework and repair videos 1-8
« Last Edit: December 25, 2014, 07:31:29 pm by miguelvp »
Offline gildasd
« Reply #2 on: December 25, 2014, 08:14:40 pm »
Ta mate, will check.
Dave's imput would have been nice because he knows marine environment and he does not waffle about for 8 videos.
(Unless he does a USB power supply.)
Offline miguelvp
« Reply #3 on: December 25, 2014, 09:53:02 pm »
You can always skip to the one about tracks and edge connectors:
But I would recommend that you watch them all as well as the soldering lessons.
Offline Rerouter
« Reply #4 on: December 25, 2014, 10:02:41 pm »
Have not watched the video but seems relevant enough,
For repairing PCB edge connector pads, or wide pads on flex PCB's used on automotive clusters,
you can grab a piece of thicker strand grounding wire, Bend it into the shape you want, hit it thin with a ball pane hammer, until slightly more than the size required, then trim to suit, the thinner you hit it, the more flexible it becomes, so you can glue it it in place and will not inhibit its flex
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: December 26, 2014, 02:13:01 am »
Apparently my brother is doing the same sort of thing, in the Navy.  He says a typical practice assignment is, drill a 1/4" hole straight through a board, and rebuild it (core and traces) as good as new.
Seven Transistor Labs, LLC
Offline miguelvp
« Reply #6 on: December 26, 2014, 02:24:23 am »
PACE Adventures in Repair, very cheesy
Part 1 of 3:
Part 2 of 3:
Part 3 of 3:
