Author Topic: $20 LCR ESR Transistor checker project  (Read 4820835 times)
0 Members and 13 Guests are viewing this topic.
Offline Yuriy_K
  • Country: ru
« Reply #10100 on: September 15, 2025, 02:11:24 pm »
For precise measurements of small inductances using the resonance method, it is necessary to select a measuring capacitor according to the given method. The values ​​that need to be paid attention to are underlined in red. I selected from several hundred SMD and film capacitors.
P.S. High resolution file, transfer to your computer to view.
Offline reverse
« Reply #10101 on: October 13, 2025, 06:12:48 am »
Hi. As several people mentioned in this thread I get horizontally reversed display image on my clone meter when trying to use the Rev804En(8x15)16Mhz from the indman's download resource -- "M328 WEI M8".  Can someone compile and put for download the 16 MHz firmware, one push-button only, and with correct for these displays setting. Any hints for activating calibration mode on this version are also welcome. In case there is an earlier versiion already compiled would you point it to me? Thank you.
« Last Edit: October 13, 2025, 08:55:22 am by reverse »
Offline Yuriy_K
  • Country: ru
« Reply #10102 on: October 13, 2025, 09:07:25 am »
With the settings specified, you can only make this version...
The following users thanked this post: reverse
Offline reverse
« Reply #10103 on: October 13, 2025, 10:29:27 am »
This one (1.13k) controls such display perfectly! Большое спасибо!
Offline Feliciano
  • Country: ve
« Reply #10104 on: October 14, 2025, 03:57:36 am »
In most cases, putting the 3 clips together call the calibration wizard.
Offline reverse
« Reply #10105 on: October 16, 2025, 07:31:29 pm »
I knew that but that became possible only with version 1.13k that Yuriy compiled specifically for my case. The version from indman's resource was poorly configured.
Offline madires
  • A qualified hobbyist ;)
« Reply #10106 on: October 17, 2025, 11:24:32 am »
This time just a few improvements.
v1.56m:
- Option to skip first probing after power-on when in auto-hold mode (UI_SKIP_FIRST_PROBING, suggested by Bohu).
- Updated Makefile to use avr-objdump instead of avr-size to show firmware size (avr-size lost -C option).
- Fixed V_BE issue in BJT output for some special Darlington pairs with B-E resistors (reported by Yuriy_K@EEVblog).
- Added option to auto-trigger RCL monitor when an R, C or L is connected to probes #1 and #3 (UI_PROBES13_RCL, suggested by indman@EEVblog).
Please download at:
- https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware
- https://github.com/kubi48/TransistorTester-source/tree/master/Markus (soon)
The following users thanked this post: indman, pepe10000, Vague, Feliciano, Fuzzy Star, edgard22, Yuriy_K, Polf, sp3rat, ltz1000a
Offline sp3rat
« Reply #10107 on: October 17, 2025, 08:34:54 pm »
I changed "avr-size -C"  to "avt-size --common" - it is working too.
Offline Yuriy_K
  • Country: ru
« Reply #10108 on: October 18, 2025, 07:20:22 am »
This change doesn't work for me...
Offline indman
  • Country: by
« Reply #10109 on: October 18, 2025, 12:11:55 pm »
v1.56m:
I don't quite understand what the point of this option is? If you need to quickly access the main menu, there is already an option UI_MAINMENU_POWERON_BUTTON
« Last Edit: October 18, 2025, 12:14:58 pm by indman »
Offline madires
« Reply #10110 on: October 18, 2025, 01:07:41 pm »
If you have an older version of avr-size then keep using it (therefore it's still in the Makefile, just commented out). Newer versions dropped the -C option.
Offline madires
« Reply #10111 on: October 18, 2025, 01:13:32 pm »
Yes. The output with the old -C option is a bit nicer (includes percentage).
Offline madires
« Reply #10112 on: October 18, 2025, 01:47:22 pm »
v1.56m:
Some users prefer to power on the tester, then connect a component and run the probing cycle. The automatic first probing cycle is a kind of nuisance for them.
The following users thanked this post: sp3rat
Offline indman
  • Country: by
« Reply #10113 on: October 18, 2025, 01:51:48 pm »
Controversial logic. But does religion not allow them to connect the part before turning on the tester for the first time?  ;)
Offline Feliciano
  • Country: ve
« Reply #10114 on: October 18, 2025, 02:56:03 pm »
Probably indman only let the option in the menu. Perhaps you can double click the button to access it.
Offline K.G.
« Reply #10115 on: October 26, 2025, 01:29:47 pm »
Hello,
I'm new here and have already read a lot of posts.
My LCR-TC2 is unfortunately defective. :'(
A stupid mistake, I didn't discharge the capacitor during a measurement. From what I could see, the Atmel 644 is defective.
I can solder in a new 644, the hardware is there.
Is it possible to program a different 644?
Even to install a different firmware. Are other components perhaps defective?
Is there a howto online that I can read?
Thanks a lot for your help.
Karsten
« Last Edit: October 26, 2025, 01:31:33 pm by K.G. »
Offline snapper
« Reply #10116 on: October 26, 2025, 01:43:53 pm »
Hi, there are ISP pins at the top edge, so that shouldn't be a problem.
You'll need a programmer, though, like USB-ASP. Regards
« Last Edit: October 26, 2025, 02:17:07 pm by snapper »
Offline K.G.
« Reply #10117 on: October 26, 2025, 02:45:19 pm »
OK, that's no problem.
Which programmer would you recommend and
which firmware is compatible with this LCR-TC2?
Offline K.G.
« Reply #10119 on: October 31, 2025, 03:01:24 pm »
I've been trying to compile the necessary files, but I keep getting errors.
I'm not very experienced with this.
Does anyone have suitable *.hex files for my TC2 with the 644?
Thanks a lot!
Offline snapper
« Reply #10120 on: October 31, 2025, 03:39:13 pm »
Try this
Offline K.G.
« Reply #10121 on: November 02, 2025, 12:08:31 pm »
I'm having trouble getting the bootloader for the 644pa to work with the Arduino setup.
I'm using an Arduino as an ISP, but it only has a 328p Atmega bootloader in the Arduino IDE.
What can I do?
Offline madires
« Reply #10122 on: November 02, 2025, 12:56:25 pm »
The Transistortester doesn't need a bootloader.
Using an Arduino as ISP programmer:
- take an Arduino and flash the "Arduino ISP" sketch (Arduino becomes an ISP programmer)
- wire the ISP (six wires from Arduino to Transistortester)
- run avrdude with the Arduino as ISP programmer and flash the Transistortester firmware (firmware and EEPROM data) to the Transistortester
BTW, there are tons of guides on how to use an Arduino as ISP programmer.
Offline snapper
« Reply #10123 on: November 02, 2025, 01:39:19 pm »
It might also be useful to tell him the settings for the fuse bits.
Offline K.G.
« Reply #10124 on: November 02, 2025, 01:44:00 pm »
The 644 doesn't have a bootloader, so it's a new replacement
because the old one was damaged by a power surge.
Using the Arduino as an ISP works, I've set everything up.
