Author Topic: $20 LCR ESR Transistor checker project  (Read 1780802 times)
0 Members and 11 Guests are viewing this topic.
Offline 001
  • Country: aq
« Reply #5925 on: October 11, 2019, 11:57:24 am »
001, madires and i explained russian forum to you that ESR02PRO will inflate readings inductance coils for more than 1H. If these results do not suit you, then complain to ESR02PRO manufacturer.
Why? I read authors manual and it says about -10% for L above 1H and  -20% for L above 10H
But I got +100% for 5H!
« Last Edit: October 11, 2019, 12:01:29 pm by 001 »
Offline madires
  • A qualified hobbyist ;)
« Reply #5926 on: October 11, 2019, 12:24:29 pm »
What a "large inductance mode" is? How to activate it?  :-//
ESR02PRO is marked 0.01mH-20H on a front panel
I was talking about the LCR meter (DE5000). I don't have that model, but most have a button to select between serial and parallel measuring mode. Serial mode is meant for low impedance and parallel for high impedance.
« Last Edit: October 11, 2019, 12:28:28 pm by madires »
Offline 001
  • Country: aq
« Reply #5927 on: October 11, 2019, 12:28:45 pm »
I was talking about the LCR meter (DE5000). I don't have that one, but most have a button to select between serial and parallel measuring mode. Serial mode is meant for low impedance and parallel for high impedance.
DE5000 is ok. I use it everyday. And choke is factory marked as 5H
Offline timelessbeing
« Reply #5928 on: October 15, 2019, 05:06:51 am »
ttester was mentioned recently on the 'Andreas Spiess' Youtube channel. He thinks very highly of the developers.
Andreas does mostly microcontroller, sensor, and RF stuff. Worth a look.
It was also featured on Hackaday (back in 2015. Wow it's been going a while):
https://hackaday.com/2015/04/24/review-transistor-tester/
Offline madires
« Reply #5929 on: October 15, 2019, 01:11:35 pm »
One page back beanflying linked the video already. ;)
The following users thanked this post: 001
« Reply #5930 on: October 16, 2019, 04:06:35 am »
it's worth mentioning again  :)
Offline Macbeth
« Reply #5931 on: October 16, 2019, 10:28:29 pm »
If Andreas Spiess is worth mentioning again, so is Dave who chucked it aside in a prior mailbag video and copped a lot of flack for it!
Online beanflying
« Reply #5932 on: October 16, 2019, 11:19:20 pm »
Given the heft of this thread it might be worth seeing if @torch if he is still reading could mod his opening post a little to include them there. Or better yet make the opening post partly a curated index to notable content or resources?
Coffee, Food, R/C and electronics nerd in no particular order :)
Offline rhb
« Reply #5933 on: October 16, 2019, 11:37:12 pm »
Why not step up the game and test breakdown voltages and provide curve tracing and data output via ASCII over a USB serial port?
BSIDE has the AVR based OSSW/OSHW covered at a good price.  Peak has considerably more to offer in the DCA75, though not as good a package as the BSIDE.  But neither will measure breakdown voltages and a large number of other important datasheet parameters.
Really, this is all so "last year".
Reg
Online beanflying
« Reply #5934 on: October 16, 2019, 11:44:38 pm »
Reg
Peak shmeak everyone needs to just needs to get lucky or pony up for one of these. Arriving in my shack early next week  ;D Or add one of the Thai made curve tracers to your collections eBay auction: #291319027845
« Reply #5935 on: October 17, 2019, 04:03:40 am »
True but didn't he revisit it in another video a short time later after he learned some details, and decided it was actually cool.
« Reply #5936 on: October 17, 2019, 04:17:09 am »
That is an extension explained in the documention.
overkill
Pretty sure it does as of a few updates ago.
Many people have suggest that the tester should also do x, y and z. The answer is still the same: You missed the minimalist point of the project. It's intended to run on basic hardware, low part count, and low cost. You can easily breadboard it. Any fool can over-engineer something.
But it is open source so have at 'er.
The following users thanked this post: 001, Jacon
Offline 001
  • Country: aq
Offline rhb
« Reply #5938 on: October 17, 2019, 06:39:25 pm »
I scavenged some semiconductors out of an electronic fluorescent lamp ballast.  They were marked, so I was able to look up the datasheets.  A couple of the parts were BJT switching transistors with a 700 Vces breakdown and 400 Vceo sustaining.  Digikey stocks them for $1.10.
The BSIDE and the Peak told me a bit about them, but mostly just that they  still appeared functional.
I happen to think it might be useful to be able to measure more datasheet parameters than the BSIDE or Peak can.    And I don't want an analog curve tracer.  I want to put a part in a fixture, close the lid, generate a datasheet for it, put it in a numbered bag and add it to a parameter searchable inventory even if it is a house marked part.  And not spend $20k+ for being able to do that.
« Reply #5939 on: October 18, 2019, 01:20:02 pm »
Me too!
Offline BradC
« Reply #5940 on: October 18, 2019, 02:33:24 pm »
Me too!
It's open source and there are two of you, should be a doddle.
The following users thanked this post: JoeO, 001
Offline rhb
« Reply #5941 on: October 18, 2019, 08:38:11 pm »
Yeah, sure. Piece of cake.
You design a digitally adjustable HV supply and get back to me about how easy it was. Next generate pulses 50-500 us long with a 1-2% duty cycle at up to 1 A and measure the voltages and currents.  Then collect all the datasheet parameters and curves.  Take a look at the manual for a Tek 57x curve tracer for how it was done 50 years ago.
Go price an Agilent 4155A or 4156A  used on ebay.  The Arduino based tester is very nice.  But I'm suggesting that something much more capable can be built for $100-200.
« Reply #5942 on: October 20, 2019, 03:32:20 am »
mentioned again @ 16:50
Online beanflying
« Reply #5943 on: October 20, 2019, 03:42:09 am »
For those wanting a better component whizbang datasheet generator go start your own thread and by all means link it here but glorified Arduino run from batteries is NEVER going to be the hardware or the place to make it happen. It is what it is and in spite of owning two sets of expensive LCR tweezers mine is still seeing some use in my on site bag.
Offline madires
« Reply #5944 on: October 20, 2019, 02:47:00 pm »
Yep, we have no intention to develop a Transistor Tester HV Ultra. That might be an idea for a commercial product, and I doubt such a tester would be inexpensive. It would be also a niche product with a market for just a few units. The success of the current design is based on its simplicity and low cost. It makes my happy that so many people can afford a transistor tester helping them to repair electronics or to upcycle components.
The following users thanked this post: 001, Willem52, indman, pepe10000, Jacon, pierreraymondrondelle, Obelix2007, Abacab
Offline blurpy
  • Country: no
« Reply #5945 on: October 23, 2019, 05:13:44 pm »
I bought a GM328 kit from Banggood, but they didn't send me all the capacitors, and their support person was not very helpful.
I need to get hold of a matching capacitor for the free spot on the top by the terminal.
The assembly instructions lists this:
ceramic capacitor
 100nF 20%
 silk( 104)
 RAD0.2
There is no mention of voltage rating here, and I'm not sure if it's important or not. Will 104s with a 50v rating work ok?
Offline madires
« Reply #5946 on: October 23, 2019, 05:52:22 pm »
Your kit is an AY-AT type clone and the missing cap is the bypass cap for AVCC which is 5V. So a 50V 100nF MLCC would be fine.
The following users thanked this post: pepe10000, blurpy
Offline blurpy
  • Country: no
« Reply #5947 on: October 23, 2019, 06:06:53 pm »
Thank you  :)
Offline Phenixg
« Reply #5948 on: October 29, 2019, 03:52:41 pm »
Have any of you guys checked how accurate this similar product "LC100-A Digital LCD High Precision Inductance Capacitance L/C Meter" is  compared to the AY-AT? It is only limited to L and C measurements and it is boasting some impressive characteristics.
Offline madires
« Reply #5949 on: October 29, 2019, 05:48:14 pm »
That L/C meter is based on an oscillator and frequency counter. Therefore it's more accurate, but it can't measure additional parameters.
The following users thanked this post: Terry Lingle, pepe10000, Phenixg
