Author Topic: $20 LCR ESR Transistor checker project  (Read 5223632 times)
0 Members and 15 Guests are viewing this topic.
Offline Cosmic_Starlight
  • Country: co
« Reply #9775 on: November 30, 2024, 08:02:52 pm »
Yes, Really! There is no ISP connector on the AY-AT board. You either take the ATM328 out of the socket and put it into the adapter board I suggested for programming (which is connected to the USBASP), or you solder this unsightly wire fiddling to the socket of the AY-AT board every time you program. But do as you see fit!
he also delivers this adapter to Colombia  https://www.ebay.com/itm/404390299187
Am sorry i didnt mean to sound ungrateful, but like i said i might or might not also need to buy another screen so i need to take the screen into the budget of the repair
That device you suggested for its price+shipping i could get just the usbasp programmer locally
And yes i agree its very unsightly but i need to get this thing working first atleast.
i can always spend the time later and make it prettier
I also would like to avoid having to remove it several times in case i flash the wrong fw or didnt set up screen correctly and risk breaking off a leg of it
Offline hapless
« Reply #9776 on: November 30, 2024, 11:06:55 pm »
If you're still thinking about replacing all those yellow capacitors, I really see no reason to do that. You have ceramic capacitors, most are multi-layer, and they don't need to be a different type than they are. If they short out or don't have the right capacitance, that's different, but if they are good, leave them in.
What I would like to see is if you have an LED in the test socket, does it blink a few times several seconds after you apply power like you did before. This is basically just to see if the ATMega is programmed at all.
The following users thanked this post: Cosmic_Starlight
  • Country: co
« Reply #9777 on: December 01, 2024, 12:44:23 am »
the one time i did sort of manage to get it to turn on (as in press encoder led lights up and screen is solid white) but holding down the power button did nothing i had to remove power to turn it off
what i do need to replace is the two s9012 transistors at the very least, maybe the other one, and maybe the 7550 too just to be sure
i already tried feeding 5v to atmega vcc with screen on and same deal, screen is solid white, i dont think the led thing would work at all since doesnt the device ask you to calibrate it upon first turn on ?
Offline carrascoso
« Reply #9778 on: December 01, 2024, 05:09:52 pm »
The author of this video is me.   :-DD :-DD
The cables with the connector soldered FIXED directly to the board, is super comfortable for programming.
Not having to disassemble the screen, remove the AtMega from the socket, plug it into the programmer or into the breadboard to program it.
And after programming the AtMega, put everything back together in the tester.
This way, you can program the AtMega quickly without so much hassle.
Offline hapless
« Reply #9779 on: December 02, 2024, 04:42:03 am »
[...] doesnt the device ask you to calibrate it upon first turn on ?
I think it will try to test first and complain about being uncalibrated later. Since I always blow out the pre-programmed firmware as soon as possible, I have no memory of how it works. But I don't think it's any different than what the k firmware does.
The programming header can be installed directly onto the board or affixed nearby and doesn't really need to be as complicated as in the video, but keep wires from the board to the header short. Permanent stray capacitance and resistance are not something you want to add a lot of.
  • Country: co
« Reply #9780 on: December 02, 2024, 06:14:33 am »
i will try and go downtown this week and buy replacements for all transistors and the 7550 and TL431  (closest replacement ive been able to find for the 7550 locally online is a LM2931AZ-5.0RAG whose pinout is different so i might have to do some fiddling like bending the leads or soldering some jumper wires and then shrink wrap them)
also buy all caps just in case one is shorted or bad, buy 3 crystal oscillators while am it too (8-16-20)
and most importantly another spare atmega and the usbisp programmer for it and the connectors and wires to solder the female port to the tester
also does anyone have a list lying around of the list of capacitor values this thing is supposed to use ? i suppose i could also look at mine note them all down and just say in the store give me x ammount of capacitors that say 102 on them and such
but i think it would be best if i just straight up asked for the specific values (that the chinese AY/AT clone is supposed to have from factory atleast)
also i saw a video of a guy that had a similar issue to mine (turns on red led is on but his screen is solid blue, tho his screen pcb is blue not green like mine) and he said in the comments he later fixed it by replacing the crystal that he was supplied with the wrong one
i cant do the led test right now since both S9012 are shorted between E and C
ive attached a photo that i was dm'ed on reddit from another guy would there be a problem if i did it similarly like this using super thin wiring ? (closest i have is some old cat5e wires that i used to use on a protoboard)
Offline Yuriy_K
  • Country: ru
« Reply #9781 on: December 02, 2024, 07:07:19 am »
I did not understand why there are two S9012 pnp transistors in the circuit and one? The other two S9014 npn - this is clear from your circuit. The author of the k-firmware writes that the highest accuracy of his firmware during measurements is guaranteed by an 8 MHz quartz. And this is true, but I managed to make some changes to the source texts and increase the accuracy for a 16 MHz quartz (see the examples of my firmware on page 277). But this is the limit for which you still need to select some elements of your circuit. As an example, 22 pF capacitors in a quartz generator should be reduced to 15-18 pF, etc. The example of connecting the programming connector you showed will not allow you to properly calibrate and work normally with the tester. It needs to be unsoldered. Here is an example of my firmware on a display similar to yours.
  • Country: co
« Reply #9782 on: December 02, 2024, 04:50:25 pm »
Wait a minute so you mean to tell me that its not as simple as just swapping the crystal for a faster one and recompiling the fw but i would also need to change capacitors values as and other things as well ?
Also could you please tell me what screen is that (what specific model)
only ones ive been able to find locally online are the ST7735B that has 11 pins so is no good to me and another ST7735S that has 8 pins so it will fit but idk if the pins are in the right order
Offline Feliciano
  • Country: ve
« Reply #9783 on: December 02, 2024, 05:45:55 pm »
For 8MHz -> 16MHz you change the crystal and build/flash the firmware. 20MHz is not stable enough, so we don't recommend it.
The 22pF Capacitors are there for helping the oscillation. Maybe we could fine-tune that, but normally it's not required.
And, like Yuriy_k said, the AY-AT clones I've seen uses two NPN and one PNP (being the other TO-92 the regulator). Maybe that was the error in the first place? You could trace the voltage path to confirm whether the polarity would it be right for one type or the other.
  • Country: co
« Reply #9784 on: December 02, 2024, 09:37:30 pm »
i am a dumbass i got confused because the numbers were very close youre both absolutely right, there are two  NPN S9014 and one PNP S9012, and the shorted ones between E and C are both the S9012 T3 and T1 S9014
and so a ST7735 screen in 128x160 should be fully compatible with this firmware (provided i get the version that has 8 pins not 11) ?
Offline Per Hansson
« Reply #9785 on: December 02, 2024, 10:23:40 pm »
I bought himself DTU-1701. I painted a complete schematic diagram
https://yadi.sk/d/yW8xa5NJgUo5z/BSideESR02(DTU-1701)/Schematic%20diagram
Red color means changes made to the scheme:
1. Replace the frail  7150 on the LP2950-5.0(better MCP1702-5.0)
2. Replace  TL431 on LM4040A (R2A)
3. Added ceramics capacitors 10mkF on LP2950 input  and Vcc processor(pins 4-6)
4. Control divider resistors R21-R22 for voltage replaced 47kOm, control point moved to the collector Q2 (optional).
5. Capacitor C10 deleted - normal work without it.
6. Replace quartz at 16MHz (optional).
Revision board 3.1 - changes in comparison with earlier BSideESR02 virtually none except for a correct wiring ICSP connections-now all your contacts conveniently separated by the connector. Photo board to upgrade and after it will be lower.
Firmware:
New English and Russian k-firmware revision 813 for this clone  https://yadi.sk/d/yW8xa5NJgUo5z/BSideESR02(DTU-1701)/Firmware/Karl-Heinz%20K%C3%BCbbeler%20
Hello Indman, I have a question about point 4 in the above quote.
If I've understood it right moving the R21-R22 divider to Q2 would get rid of the 9µA quiescent current that the Bside ESR02 draws when it is off right?
But what does changing the resistors from 1M to 47k improve?
Also the moving of the battery negative wire to the power input jack what does that improve, is it for better routing?
Online CaptainBucko
« Reply #9786 on: December 03, 2024, 03:19:32 am »
That was me! You could definitely use CAT5e wires, it just needs to be thin enough to reliably solder to each pin. The connector should be glued down so that the wires do not suffer metal fatigue and break off. You can use use any connector you like but you may have to make up an adapter cable from the ISP adapter. For this purpose I prefer solid core wire, as it bends and holds it shape. I use wire wrap wire myself.
The ISP adapter I use is this one: https://www.ebay.com.au/itm/353547444898
  • Country: co
« Reply #9787 on: December 03, 2024, 04:29:22 am »
lmao small world huh... and thats the exact usb programmer am eyeing on getting, if i cant get a port to solder to the atmega i will have to use my old protoboard and flash it that way
tho i was adviced against soldering wires to the atmega since they could throw off the calibration or make it have issues under normal working conditions
next thing you know the chinese seller i bought this from might chime in here too lmao since you and the spanish guy in took the yt screenshot from has also chimed in
Offline indman
  • Country: by
« Reply #9788 on: December 03, 2024, 05:46:15 am »
Yes, you are correct in your understanding of this decision.
In fact, this replacement will not improve anything, so you may not use it. But from an engineer's point of view, the output resistance of the power supply we are going to measure must be matched to the input resistance of the Atmega's measurement port. It is for this reason that the author chose a 10k/3.3k divider to supply 9V and also to reduce the maximum allowable input voltage below 5V.
This solution allows you to simply hard disconnect the 9V battery if you connect external 9-12V power. You don't have to do that if you want to. :)
The following users thanked this post: Per Hansson
Offline Per Hansson
« Reply #9789 on: December 03, 2024, 05:00:21 pm »
Thank you Indman for the explanations, I really appreciate it!
Sometimes I wonder how my own brain works though, reading the description of the file: Hiland-M644-Booster-Mod.png
Under the repository: https://github.com/madires/Transistortester-Warehouse/tree/master/Hardware
It's wonderful when you Google something and find an explanation: written by yourself! :D
Edit: here is a photo of the way I did it, just removed R21 and replaced it with a through hole resistor, so no need to cut the trace this way...
Works great and now 9µA quiescent current is down to only 0.2µA
« Last Edit: December 05, 2024, 08:20:52 pm by Per Hansson »
  • Country: co
« Reply #9790 on: December 07, 2024, 01:40:50 am »
so i finally went downtown today to find replacement parts for it and here its what i could get
S9014 ----> BC547
HT7550 -----> LM78L05
S9012 ----> N3906
only as a last ditch effort i tried one last store if they had any of the original references, and i bought the last two S9012 they had in stock, think i bought two TL431 too jut in case, they didnt have any S9014 nor 7550
bought all new caps, and two crystals of 8 and 16mhz
bought a spare atmega too but all i was told is that they were generic, another store had it for twice the price think generic too but it came with a bootloader already i just bought the cheaper one
no store had a programmer for it, the one store that had one like it was red pcb with a huge zif socket and its price was more than a new gm328 unit so i didnt buy it obviously
am fully aware all the replacements i bought have a different pinout so i also bought some 1.5mm heatshrink tubing
i just realized i might have made a mistake and asked for a replacement of a 7750 not a 7550, i dont know if the replacement i bought for it will work or not, or if i should just go and buy a different one again that has a lower dropout voltage (hopefully i didnt apply too much heat to the 7550 when desolderingg it)
« Last Edit: December 07, 2024, 03:05:05 am by Cosmic_Starlight »
Online CaptainBucko
« Reply #9791 on: December 08, 2024, 12:46:15 am »
I don't see a 6pin J3 connector here, i.e. I have to make do with the Chinese firmware which is pre-installed, right ?
As mentioned by others, you can convert your PCB from a LGT8F328 to Atmega328p to run the latest v1.53m firmware, with a bit of extra wiring to add an ISP header to the PCB.
Your PCB is slightly different from mine, but these photos should give you some guidance. Tnx to others before me who created solutions this is based on.
« Last Edit: December 08, 2024, 02:46:48 am by CaptainBucko »
  • Country: co
« Reply #9792 on: December 08, 2024, 04:08:15 am »
well today it certainly has been a rollercoaster
so today i replaced all transistors and ICs so i replaced T1, T2, IC2,and T3, also replaced both caps of the crystal and the crystal, tried replacing both 10uf caps but the one under the screen the one i got was too tall so i had to put the original back in, the other one i did replace
so before attempting to turn it on again i made doubly and triple sure that there were no solder bridges on any transistor or IC
i also havent put back the TL431 (IC3) back in for the time being
so i put the battery in, press the encoder, screen is white, then it disappears, and wow, it appears to be alive, , however its function seemed to be a bit erratic, like it would keep cycling asking me to calibrate and such, there was one time it booted me to the main menu and i could scroll up and down it no problem, so i put one of the S9012 i bought and it measured it alright (as much as an uncalibrated unit could)
but the unit wouldnt turn off on its own for whatever reason, even when left alone for a few seconds, also the battery voltage when it first turns on seems to be erratic too not to mention there seems to be a character missing on screen (when it first turns on?
so i searched for a YT video on how to calibrate this thing, and i knew before hand that booting it up with zif socked 1-2-3 shorted it would start on self test mode and calibrate itself, well so did they guy on the yt video, so i did just that, one small cat5e wire going from pin 1 to pin 2 and from pin 2 to pin 3 and tried turning it on buuuuuuut....
now am back at a solid white screen again, on he atmega vcc pin i read 5.0 something volts so i dont think is that ?!
i dunno, if trying to calibrated it without the TL431 IC3 in place was an error or not
so what could have happened ? i cant hear the faint fizzing noise i could hear before so idk what is wrong with it
i will attach some photos of when it worked (it wasnt very long)
  • Country: co
« Reply #9793 on: December 08, 2024, 05:29:19 pm »
OK this is making me want to pull my hair out so first thing I did today was try and turn it on again and it did but for whatever reason it thought that there was a transistor connected and it was measuring some capacitance, so I tried putting a transistor in the zif socket and when I turned it on, white screen again
So that s where I am currently, no idea what's wrong with it or what to check
I also found a wall adapter for it from an old router, does this device expect center positive or center negative ?
Offline Feliciano
  • Country: ve
« Reply #9794 on: December 08, 2024, 05:48:35 pm »
So it was sort of working until the moment you shorted T1,T2,T3?
Did you measure whether one or more of those terminals had 0V or 5V static? (like having a damaged protection circuit). Because maybe you could damage the MCU if that was the case :(
You could measure now whether those have a short to ground or to 5V.
PS. Normally we work with 9.0Vdc center positive, unless you're talking about music pedals.
« Last Edit: December 08, 2024, 05:53:34 pm by Feliciano »
  • Country: co
« Reply #9795 on: December 08, 2024, 05:54:49 pm »
I didn't measure any voltage anywhere, it still sort of works, like I said I turned it on today and even if I kept removing battery power it kept thinking there was a transistor connected and it kept measuring it
That was until I put a transistor in and its now back to a solid white screen
So I can't try powering it from a 12v wall adapter ?
The following users thanked this post: sarahMCML
Offline Feliciano
  • Country: ve
« Reply #9796 on: December 08, 2024, 06:05:42 pm »
If you disconnected the programming cable, and the MCU detects there is a phantom component there, probably is damaged now.
Some units have a protection section of SRV05-4 plus a TVS or a Zener between Vcc and GND, that is located very close to T1,T2,T3. Sometimes those parts get damaged (let's say somebody forgot to discharge an electrolitic capacitor), and if still being used can damage your new microcontroller. Shall that parts get damaged (shorted to Vcc or GND), you could remove it, replace the ATmega, and try again.
Regarding 12V or more, your series voltage regulator could accept that voltage and still deliver 5V, depending on whether it's a good quality component or a lousy fake. You know the reputation of the store you bought those from, so it's up to you to decide and proceed.
  • Country: co
« Reply #9797 on: December 08, 2024, 06:12:31 pm »
You mean those tiny smd components below the zif socket ? I don't have any tools to work on them, done even know how to about testing them of they're good
I also haven't connected any programming cable since I don't even have one yet
I still don't understand how it could've gotten damaged if what I did was what you do when it asks you to calibrate it
Also I don't understand how it didn't turn on last night but today did until I put a transistor in the zif socket
Offline Feliciano
  • Country: ve
« Reply #9798 on: December 08, 2024, 06:15:10 pm »
Something like the attached, and the related "b" schematic. Once you know how it is internally made, you can deduce how to test it, and if damaged, elucubrate on how could damage the MCU when it tries to pull the terminals high and low to measure a component.
« Last Edit: December 08, 2024, 06:20:13 pm by Feliciano »
  • Country: co
« Reply #9799 on: December 08, 2024, 06:23:26 pm »
So I just put my dmm on continuity mode so it beeps I put negative lead on the battery negative pad on PCB and it only beeps on the smd components on the bottom side of the two on the left and the 6 legs one only on the right side middle one
And the atmega only beeps on its ground pins nowhere else
