I guess so. Hmm, does this mean that if you come up with an idea, you should post it all over the net? That way, if China copies and manufactures it, you can buy it for less money and effort than if you made it yourself?
That's the plan
. I know I don't have that power, but all this small tools manufacturers are paing attention on what is posted all over the interweb so here are my suggestions:
Dear clones manufacturer, please consider to add a companion case for this tester with an exposed smd test area like the ESR02PRO or provide an smd accessory, LiPo battery, microusb port for external power, recharge the battery and usb serial interface.
While you're at it, please combine the two firmware variants m and k and provide an open souce Marcus-Heinz GitHub repository.
Thank you
Mauro
