Author Topic: $20 LCR ESR Transistor checker project  (Read 3475526 times)
carrascoso, Strateg58 and 23 Guests are viewing this topic.
Offline indman
  • Country: by
« Reply #5100 on: September 10, 2018, 01:37:01 pm »
flodo,thanks for video - the program works normally, I don't see any problems in work of a tester. :-+
Offline madires
  • A qualified hobbyist ;)
« Reply #5101 on: September 10, 2018, 01:41:40 pm »
flodo,сan you make small video of work of the LCR-TC1 with a new firmware U4? :)
I think it is better to wait for a video from someone with the transistor-mod since I am not sure if it behaves correctly.
If you press the button for at least 300ms at power-on the tester will enter the auto-hold mode (no cycling, blinking cursor at the bottom right). And after displaying the result of the last check two short button presses will trigger the menu. If this is working fine your firmware for U4 should also run without any problems with the k-firmware.
Offline indman
  • Country: by
« Reply #5102 on: September 10, 2018, 01:59:02 pm »
Still it is possible to change an operating mode of the Test button in config.h
#define UI_AUTOHOLD  :)
Offline flodo
« Reply #5103 on: September 10, 2018, 03:26:52 pm »
Like this?
https://www.youtube.com/watch?time_continue=1&v=tloRxvvWxuc
Btw, looks like the battery settings are wrong - right (15.x V)?
« Last Edit: September 10, 2018, 03:28:37 pm by flodo »
Offline madires
« Reply #5104 on: September 10, 2018, 03:57:56 pm »
Yep, but I've noticed some bad characters/texts in the menu. Have you updated also the EEPROM? And yes, the battery voltage is wrong. My guess is that BAT_DIRECT isn't enabled (BAT_NONE and BAT_DIVIDER need to be disabled).
Offline indman
  • Country: by
« Reply #5105 on: September 10, 2018, 05:08:42 pm »
The wrong voltage of the battery and excess symbols are small malfunctions which are easily corrected.
Config.h
#define BAT_R1           0
#define BAT_R2           1
The most important that management by the Test button works without problems. :)
« Last Edit: September 10, 2018, 05:18:33 pm by indman »
Offline madires
« Reply #5106 on: September 10, 2018, 06:04:43 pm »
Those settings are for older versions (IIRC, before 1.32m).
Offline indman
  • Country: by
« Reply #5107 on: September 10, 2018, 06:11:50 pm »
I have opened the config.h file from your distribution kit 1.33m. In him I see these settings:
 *  Voltage divider for battery monitoring
 *  - BAT_R1: top resistor in Ohms
 *  - BAT_R2: bottom resistor in Ohms
#define BAT_R1           10000
#define BAT_R2           3300
 It is wrong or doesn't work any more?
Offline seanspotatobusiness
« Reply #5108 on: September 10, 2018, 06:39:17 pm »
My AY-AT clone doesn't turn itself off if left alone for several minutes and also doesn't turn off if I try to switch it off manually. If I use the rotary encoder to self "switch off", the screen refreshes and the tester doesn't switch off. Does this suggest a fault? I hope to replace the microcontroller with one flashed with 1.33 (m-firmware) whilst it the one it came with is running 1.12.
Offline madires
« Reply #5109 on: September 10, 2018, 06:53:20 pm »
#define BAT_R2           3300
They work, but they are meant for BAT_DIVIDER. BAT_DIRECT ignores them and the firmware will be a few bytes smaller. Therefore BAT_DIRECT is the preferred setting in case of a direct battery monitoring without any voltage divider.
The following users thanked this post: indman
Offline madires
« Reply #5110 on: September 10, 2018, 06:59:38 pm »
Yes, there's something wrong with your tester. Please check the power control signal (ATmega328 PD6). It should change to low when powering off.
Offline flodo
« Reply #5111 on: September 10, 2018, 09:55:00 pm »
I attached linked to TC1 U4 firmware v0.2 - the standy mode should work now: https://github.com/atar-axis/tc1-u4/releases
The TC1 standby power consumption seems to be around 0.11mA, so my 2000mAh battery should - in theory and when disregarding self-discharging - last for around 2 years standby. That's okay but not really good... According to the datasheet the consumption of U4 is lower than 0.1uA in power-saving mode, so what is drawing so much power?
@madires: have you ever measured the consumption? what are your results?
Another question: are there any graphics somewhere like in the shipped firmware?
« Last Edit: September 21, 2018, 02:08:32 pm by flodo »
« Reply #5112 on: September 10, 2018, 11:22:49 pm »
PD6 remains at 5 volts when I select "switch off". The LED at the top of the PCB turns off whilst the rotary encoder is held down but the voltage on PD6 stays on and when the rotary encoder is released, the screen refreshes.
Offline madires
« Reply #5113 on: September 11, 2018, 10:24:53 am »
Not yet, but zappenduster did (15µA).
Just the symbols for 3-pin semiconductors. Graphics which automatically scale to the screen resolution and font size would increase the firmware size considerably.
Offline madires
« Reply #5114 on: September 11, 2018, 10:34:58 am »
Remove the ATmega, press and hold the rotary encoder and measure the voltage at PD6.
Offline flodo
« Reply #5115 on: September 11, 2018, 04:41:31 pm »
Unfortunately my U4 (STC15L104W) is now dead after all... (yes, this time it really is  :-[)
If someone in europe can offer me a new one, or tell me where I can buy one, i would really appreciate it.
Update:
After searching for a while: You can replace the STC15L104W by a STC15W104 or STC15W204. In fact I would recommend to do so because a fully charged Battery is around 4.2V, in this case there are still around 4.0V at U4 behind the diode. The absolute maximum rating of the STC15L104W is 3.6V, the STC15W104/204 has a maximum of 5.5.
Yes, I know - 0.4V will surely not destroy the IC... but it is a bad design anyway, there is not even a voltage regulation for U4.
« Last Edit: September 21, 2018, 11:40:50 am by flodo »
Offline indman
  • Country: by
« Reply #5116 on: September 12, 2018, 06:50:28 am »
There are 2 options of a chip STC15L104 with power 2,4-3.6v and STC15F(W)104 with power 3.8-5.5v, then for option with STC15F104 the diode which I have marked red in the drawing is necessary, and for option with STC15L104 - isn't necessary and is even harmful because it overestimates supply voltage by 30% above passport!
« Last Edit: September 12, 2018, 06:53:56 am by indman »
Offline indman
  • Country: by
« Reply #5117 on: September 12, 2018, 11:05:54 am »
@indman:
The STC15Wxxx is rated for 2.4 - 5.5V (not 3.8 - 5.5V like the STC15Fxxx). So the diodes shouldn't be a problem, right? Neither D3 nor D0.
Not essentially what lower threshold of voltage(2.4v or 3.8v), it is possible to use any of the chips.The main thing that top  voltage makes 5.5v.I have shown the D0 diode on a photo :)
Offline Azure
« Reply #5118 on: September 12, 2018, 11:06:37 am »
But, where is D0 on the PCB? I didn't knew about this one.
On the circuit I have drawn for the TC! I have that D0 in Indmans drawing drawn as D4, not sure if that helps you flodo.
« Last Edit: September 12, 2018, 11:12:55 am by Azure »
Offline madires
« Reply #5119 on: September 12, 2018, 11:14:39 am »
Yep, D3 is needed to power U4. And D0's purpose seems to be to bring U4's I/O pins up to nearly 5V to match the ATmega.
Offline flodo
« Reply #5120 on: September 12, 2018, 11:22:34 am »
I removed my last comment because it was totally misleading.
Let's see if I got it right now:
There are at least three variants of the STC15:
  • STC15Lxxx - supply voltage of 2.4 to 3.6
  • STC15Fxxx - supply voltage of 3.8 to 5.5
  • STC15Wxxx - supply voltage of 2.5 to 5.5
U4 is powered by the battery (via D3) as long as the 78L05 is not up yet - right? Therefore, U4 is powered by 3.5-4.0V (3.7-4.2V minus voltage drop at D3) at startup. The point is, 4.0V is too high for the STC15Lxxx and 3.5V is too low for the STC15Fxxx
U4 is then enabling the step-up (U5, SD6271) at start-up, which powers, among others, the 78L05.
Now, since the 78L05 is up, the voltage at U4 is now 4.8V (5V - 0.2V D0 drop) - which is even higher and therefore much too high for the STC15Lxxx.
The only one which does really fit both phases is the STC15Wxxx.
Removing D0 is not really a clean solution since then the I/O ports are at another level as the ATmega is.
« Last Edit: September 12, 2018, 11:58:34 am by flodo »
Offline madires
« Reply #5121 on: September 12, 2018, 11:32:37 am »
You got it right! ;)
Offline Azure
« Reply #5122 on: September 12, 2018, 12:15:52 pm »
Indman, do you have a link to that complete circuit.  I would like to compare it to the one I have drawn.  I have attached my current one.
Note: LCD sub pcb is not correct on my drawing as I just started adding in the parts for it.
I see D3 not only as a voltage drop to U4, it blocks the 5V from feeding back to the USB Lipo charger and D4 stops the V+ from the 5V supply.
I think the U4 L/F/W part numbers are worth looking into in respect to the opersting voltsges.  One concern is the F may not start up when the battery is a little low on its voltage (Edit: As flodo said in the previous post)
« Last Edit: September 12, 2018, 12:17:23 pm by Azure »
Offline indman
  • Country: by
« Reply #5123 on: September 12, 2018, 12:57:41 pm »
https://yadi.sk/d/yW8xa5NJgUo5z
You can download the schematic diagram on many clones which I have collected in one archive at this link. You come into the "LCR-T1" folder - inside there are folder "Schematic diagram" and the TC-1.spl7 file. At me isn't present in LCR-T1 clone hands. This scheme was drawn by one of owners sleska of such device from the Russian website vrtp.ru.
It is possible to open the *.spl file the SPLan program - demo version is located here https://www.electronic-software-shop.com/lng/en/demo-versionen/
« Last Edit: September 17, 2018, 05:49:47 pm by indman »
Offline flodo
« Reply #5124 on: September 12, 2018, 01:10:50 pm »
@indman: Could you please export the splan-schematic to pdf for me? i am running linux  ;D
@Azure: FIY, the U5 boost-IC is a SD6271 :) The "697" behind "AL" is just a LOT number :P
« Last Edit: September 12, 2018, 01:19:28 pm by flodo »
