Author Topic: $20 LCR ESR Transistor checker project  (Read 4327578 times)
Offline bobrov1989
« Reply #9850 on: December 24, 2024, 02:30:40 pm »
бобров1989 ,read carefully what I wrote above. There is no need to supplement this project with features that may confuse the user.
I have a different username (not sure what you wanted to show by changing it in your quote) and I've read your reply (replied to a different user if you read my post). Wanted to see if there any other ideas, thanks for your patience.
Offline Yuriy_K
  • Country: ru
« Reply #9851 on: December 24, 2024, 05:23:35 pm »
I Loss doesn't show for tantalum I had problems with - it has painted dot without any other signs.
Enable SW_CAP_LEAKAGE in config.h and see the result
Offline Yuriy_K
  • Country: ru
« Reply #9852 on: December 24, 2024, 06:51:04 pm »
hello Yuriy
have you documented the changes to the circuit somehow so that I can insert them into my layout if necessary?
Here is a simplified diagram with the latest changes.
Yes, the converter has been modified and tested yesterday.
There are no errors in the circuit.
All capacitors are ceramic, for operation at high frequencies. The output capacitor of the converter C17 must have a working voltage of at least 50 V.
NJ300A was used to adjust the frequency of the Arduino Mega 2560 quartz generator. The capacity of the cable wires is used. A deliberately larger section of known capacity is shortened to the desired frequency value. Control is carried out by the value of the output frequency period of 1 Hz with an accuracy of up to 6 digits.
« Last Edit: December 25, 2024, 06:31:35 am by Yuriy_K »
The following users thanked this post: snapper
Offline Cosmic_Starlight
  • Country: co
« Reply #9853 on: December 25, 2024, 03:00:55 am »
could this be caused by the improper calibration capacitor usage ? or is it just a slightly defective MCU ?
The tester should work also without the self-adjustment. But measurement values could be a bit off.
i mean yeah it does work its just slightly bothersome that whenever i need to measure big caps the tester cant detect it on its own and i have to manually go into the capacitance test
oh and btw i did buy today some film caps but no store had anything that wasnt a polyester one, so i bought 3 a 330nf, some other i cant remember and a 1000nf one, and i ended up using the 1000nf one to calibrate it
the values of capacitance themselves dont seem to have changed much, however the issue that the capacitance test on 1--3 it kept climbing up seems to have been fixed, for example a 100k pf cap starts of at around  86k and then stabilizes at a little over 100k pf
same deal with the 2200uf cap tested manually through the menu, it only flickers between two values (and the vloss and esr accordingly)
its still on the stock 1% resistors, that i know that i need to upgrade to 0.1% in the future
but for now i think i can be happy with the device, now i think i need to start actually use it, learn it together with the big manual and actually use it to diagnose and fix stuff
oh and swap the kinda iffy MCU on the DIY kit whenever the programmer for it arrives
also i was reading the part of the manual on how the capacitance test works, and while i didnt understand most of it it seems that even between different units of the same MCU there can be different results and thats the purpose of calibrating the unit to bring them all together ? (but i guess theres only so much it can do)
« Last Edit: December 25, 2024, 03:04:24 am by Cosmic_Starlight »
Offline snapper
« Reply #9854 on: December 25, 2024, 04:21:50 am »
hello Yuriy
has the voltage converter already been revised in the circuit you posted?
pin 16 of the HCF4060 should definitely be connected to VCC and not to Vin!?
best regards
Offline Yuriy_K
  • Country: ru
« Reply #9855 on: December 25, 2024, 06:19:27 am »
No, specifically to Vin.
  • Country: co
« Reply #9856 on: December 28, 2024, 02:03:40 am »
Hello am looking for advice if i should re-calibrate my pre-built unit or not, its running 1.13K
(i dont know if it was calibrated with a film cap or not and if it was, was it a higher quality than the ones i got ? much less if even any capacitor was used as ive seen some videos on YT of calibration of their devices and not putting a cap in while the device is almost screaming for one to be put in)
i am only wondering because a 2200uf cap reads it as 2500ish while the DIY kit reads it as 2400ish
Although reading the K firmware manual here it seems that between different units of the same MCU there can be differences ? but idk if a 100ish uf difference is a lot or not
the showdata screen says for the pre-built
R0= .23 .24 .21      C0 37 38 39pf
Ri_Hi= 21.8                  39 39 39pf
Ri_Lo= 20.5           Ref_C= 9
                              Ref_R= -10
while DIY kit says
R0= .10 .11 .09      C0 41 41 42pf
Ri_Hi= 15.6                  42 42 42pf
Ri_Lo= 12.8           Ref_C= -15
                              Ref_R= 1
the capacitor i used for calibration of DIY kit is a 1uf +/-10% Polyester film cap, brand is Suntan
ive attached a photo of the capacitors in question
« Last Edit: December 28, 2024, 02:28:13 am by Cosmic_Starlight »
Offline Yuriy_K
  • Country: ru
« Reply #9857 on: December 28, 2024, 05:35:51 am »
No one has cancelled the change in instrument readings depending on the warming up. Perform a self-test several times in a row, recording the readings, and set for your device when the readings stabilize. For increased accuracy, it is advisable to have a case. In the k-firmware menu, there is an item for adjusting readings for electrolytic capacitors. Polymer capacitors have the smallest deviations from the nominal value, as shown in the example.
The following users thanked this post: Cosmic_Starlight
Offline indman
  • Country: by
« Reply #9858 on: December 28, 2024, 07:30:02 am »
Ri_Hi= 21.8
Ri_Lo= 20.5
while DIY kit says
Ri_Hi= 15.6
Ri_Lo= 12.8
If you do not have a more serious tool for measuring RLC parameters than these testers, then it will be difficult for you to determine the actual value of your capacitance 2200mkF or another similar one and correctly configure the reading correction as Yuriy_K wrote above.
You really have different MCUs in these testers, this is clearly visible by the different resistance of the Ri_Hi measuring ports and Ri_Lo. I have highlighted these values ​​in a thicker font in your post. You should pay special attention to the quality of the MCU +5V power stabilizer!!! If possible, you should install a truly QUALITY voltage stabilizer, because the measurement results and their stability will depend on this. This is my advice. :)
Offline Feliciano
  • Country: ve
« Reply #9859 on: December 28, 2024, 11:06:47 am »
Most Electrolitic Capacitors have 20% tolerance (and they age). That's why they follow the E6-series values.
Nevertheless, besides what indman and Yuriy_k just told you, if not only a few but many capacitors are reading too high values on your k-firmware unit, you can compensate modifying the makefile and compiling/flashing again:
# The WITH_AUTO_REF option enables reading of internal REF-voltage to get factors for the Capacity measuring.
CFLAGS += -DWITH_AUTO_REF
# REF_C_KORR corrects the reference Voltage for capacity measurement (<40uF) and has mV units.
# Greater values gives lower capacity results.
CFLAGS += -DREF_C_KORR=12
# REF_L_KORR corrects the reference Voltage for inductance measurement and has mV units.
CFLAGS += -DREF_L_KORR=40
# C_H_KORR defines a correction of 0.1% units for big capacitor measurement.
# Positive values will reduce measurement results.
CFLAGS += -DC_H_KORR=0
« Last Edit: December 28, 2024, 11:14:04 am by Feliciano »
Offline indman
  • Country: by
« Reply #9860 on: December 28, 2024, 04:51:48 pm »
These makefile settings are intended for more experienced users who have had experience working with this project for more than one year and know what adjustments are best to make and what settings are best left untouched, because they can make the tester work unstable and unpredictable.
For Cosmic_Starlight, these settings are still premature and can only do harm and not benefit. ;) In addition, as I said above, in order to correctly adjust the readings, it is very desirable to have a more serious measuring instrument as an exemplary standard.
« Last Edit: December 28, 2024, 04:58:56 pm by indman »
Offline Feliciano
  • Country: ve
« Reply #9861 on: December 28, 2024, 08:09:36 pm »
I totally agree with you indman, but he keeps insisting, so I'm telling him RTFM and have fun.
  • Country: co
« Reply #9862 on: December 29, 2024, 05:59:34 am »
First of all, I want to sincerely thank everyone for their detailed responses and for sharing your knowledge. I realize this forum is highly technical, and I’ve done my best to do my homework before asking questions here (though it’s clear however much i did isnt enough). I’ve mentioned in earlier posts that I’ve read parts of the manual I thought were relevant to the question i was asking and somewhat understand the general concepts, but as a complete beginner, I still find myself struggling with some of the finer details. For an electronics engineer or someone with moderate to high knowledge in electronics, the 100+ pages might be straightforward, but for someone like me, it’s overwhelming. An analogy i can think of is like it would be that it’s easier to make a plane fly when you’ve already seen one fly or flown one before—not so much when you’ve done neither.
My main goal with this question was to seek simple guidance. I fully understand that this Chinese AY/AT clone is off-spec compared to the reference design in its stock form, even more so to professional tools, and I’m not expecting miracles from it. I also know that swapping voltage regulators or using 0.1% resistors can improve performance, but I simply dont have them right now
I was perhaps naively hoping for a straightforward answer, like: 'Yes, this kind of 100uF discrepancy is normal for this variant in stock form,' or, 'No, that seems unusual—try X or Y with what you have.' I understand this might be oversimplified, but I was hoping for guidance at that level. (though its completely understandable if its not possible i know that sometimes oversimplifying things isnt that easy)
For now, I’m working with what I have and am genuinely happy with these devices—I’m not trying to compare them to $1000 professional equipment. I’m also aware the manual mentions a 4% error for capacitance readings around 1uF, and I’m okay with that range. My specific question was whether the ~100uF difference I observed is due to MCU variance or the calibration steps and capacitors used.
I hope this doesn’t come across as me being annoyed or offended—I truly am not. I genuinely appreciate the time and effort everyone has put into responding. I’m just trying to better understand what’s realistic for this device and for my current skill level. Like for example if something could be done about the 100f discrepancy with the devices as is thats good if not that's ok too not a problem
i realized this was the best place on the internet to ask knowledgeable people about this device so thats why i came here
But i realize I might be overstaying my welcome here, and I apologize if I’ve been bothersome. Hopefully, the next time I post, I’ll have the proper voltage regulator and correct tolerance resistors and the M firmware (though I’m not sure when that will be).
Thank you again for your patience and help—it really means a lot to someone just starting out. Wishing you all the best!
Offline indman
  • Country: by
« Reply #9863 on: December 29, 2024, 07:02:27 am »
I already reminded you above that you have installed MCUs of different quality! This is just one of the important reasons why measurement results may differ, even if you did the calibration correctly and used the correct capacitors for it.
On the other hand, the difference of 100mkF for a capacitance of 2200mkF is not significant, since, subject to a 20% deviation from the nominal value, it can range from 1760mkF to 2640mkF and this will be considered an acceptable capacitance value.
Therefore, you don't need to make any more adjustments now until you gain more experience with this project. Good luck!  :)
Offline Feliciano
  • Country: ve
« Reply #9864 on: December 29, 2024, 11:45:57 am »
I think my previous answer covered that part:
« Last Edit: December 30, 2024, 01:28:18 pm by Feliciano »
Offline snapper
« Reply #9865 on: December 30, 2024, 03:31:03 pm »
@Yuriy_K
the PE6 is not brought out, does it now have to be bridged directly on the 2560?
Offline Yuriy_K
  • Country: ru
« Reply #9866 on: December 31, 2024, 04:08:58 am »
@Yuriy_K
The PE5, PE6 pins are can be jumpered  on the Mega 2560, this is shown in the diagram and indicated in the author’s description.
Unfortunately the PE6 pin is not connected
to a pin of the Arduino female connector strip. The PE5 pin_7 is connected to the connector 3 of
the PWM socket strip and can be jumpered with the PE6 pin_8 of the ATmega2560.
« Last Edit: December 31, 2024, 04:19:31 am by Yuriy_K »
Offline snapper
« Reply #9867 on: December 31, 2024, 06:06:53 am »
Sorry, but my board has no jumper !
« Last Edit: December 31, 2024, 05:41:12 pm by snapper »
Offline Yuriy_K
  • Country: ru
« Reply #9868 on: December 31, 2024, 07:31:13 am »
If you enlarge the photo from page 318, then in the upper left corner there is a photo of the changes on the Arduino board itself. These are added capacitors on the power pins and a jumper on the pins themselves, as described by the author. Check the correspondence between the pin numbers and the soldered capacitors, I initially had an error.
Offline hiei27
« Reply #9869 on: January 02, 2025, 09:15:58 pm »
hi everyone, i just got one of these testers, it came with the usbc port and an atmega328p (quad flat pack) with the 1.12 firmware. my question is is it possible to flash an upgraded firmware without desoldering it? i do not have the schematics, so i cannot rule the possibility of having mods that are unsupported by the firmware. do you have any suggestion in this regard? or i should directly try to get a different board, maybe a kit?
Offline Feliciano
  • Country: ve
« Reply #9870 on: January 02, 2025, 10:22:45 pm »
Welcome to the forum.
Normally these testers doesn't include a port for flashing. Nevertheless, for some models you can add (solder) such port without needed to desolder the SMD ATmega.
In any case, in order to be able to provide you better guidance please check whether your unit is one of the OSHW major clones, or kindly provide a photo of it.
« Last Edit: January 02, 2025, 10:25:55 pm by Feliciano »
Offline UltimateX
« Reply #9871 on: January 03, 2025, 12:12:34 am »
I have this one from ebay....
It has  1.07 FW
Could I flash it with new FW and what version please??
Specifically, in the case of using the k-version you can use directly the contents (files "TransistorTester.hex" and "TransistorTester.eep") of these folders:
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/mega328/?view=tar
or
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/mega328_2X16_menu/?view=tar
Setting of fuses for ATmega328:
lfuse:0xf7 hfuse:0xd9 efuse:0x04 (0xfc)
I know the above answer is many years old but I would like to (finally) upgrade my component tester that exactly matches the one shown in the photo preceding tom666 and madires' answers to "9a4wy", i.e. "EZM Electronics Studio M8/M168/M328_9V_V3.0" printed on top left of the PCB.  I tried finding the "classic editions" of the 1.12k and 1.19m firmware on GitHub, but I cannot find them.  Does anyone know if there are links to a repository(s) where the firmware files for these versions can be downloaded?
Please ignore the missing transistors.  They were removed to test at the time of the photo but were fine and reinstalled.   The tester works fine but I believe later firmware versions have improved accuracy, especially on ESR.
Thanks!
Offline indman
  • Country: by
« Reply #9872 on: January 03, 2025, 05:37:22 am »
Try upgrading to this version, which I've attached. It is not the latest, but it works stably and has been tested on many similar clones.
I have compiled it before for this particular model. :)
Offline hiei27
« Reply #9873 on: January 03, 2025, 06:47:51 am »
thanks for your reply, my board doesn't seem like any clones from the list you linked, it's similar to the GM328a (bgr) 1 but it uses  a usb C port (with no other pins connected beside vcc and gnd, pic attached).
Here are some pics made with a phone, i will snap some later with a microscope that i hope will be better, but maybe these will already do?
Offline indman
  • Country: by
« Reply #9874 on: January 03, 2025, 06:57:12 am »
hiei 27 , What doesn’t suit you about the factory firmware? I also advise you to first wash the board thoroughly to remove any flux and dirt!
