Products => Test Equipment => Topic started by: NiHaoMike on April 25, 2018, 04:04:23 am
Not sure if this is the right place, but there does seem to be a lot of potential!
https://osmocom.org/projects/osmo-fl2k/wiki
Summary: It is a cheap USB 3.0 to VGA converter that can be programmed to output continuous waveforms without sync gaps.
~150MSPS seems to be achievable. So with an appropriate anti-aliasing filter and output amplifier attached, it could be a pretty decent entry level AWG. Downside is only 8bits of resolution though.
