$2600 scope for a newbie just starting out? I personally think it's a waste of money. You could have bought a $100 analog scope on eBay if you're just starting out.... milk it, learn from it, study it, squeeze it for what it's worth, and if your project/skills demand more features/performance, then that's when you get say a starter DSO Rigol DS1054Z... again milk it for what it's worth, and you'll know when you need to "upgrade" to a bigger and better scope.
Buying new test equipment won't make you learn electronics through osmosis by the smell of new equipment.
Let's see, I was sophomore in High School and only had an analog VOM (a kit I built myself), cutter, pliers, philips and flat head, and some drill bits and ferric chloride. -- from these primitive tools, I've built a power supply, a regulated power supply, a phono preamp, stereo preamp, stereo amplifier, crossover, AM radio, FM radio, digital clock, "knight rider" running lights, etc... I made my own PCB using a xerox machine, tracing paper, nail used as a punch, and a hammer and some permanent marker pens. The thought of buying a scope, or a signal generator didn't even enter my mind.
You don't need $5K of new equipment in your lab before you can start learning electronics!
Edit: Oops, forgot another tool... a 30W soldering iron that keeps getting hotter and hotter until you can't hold the handle anymore, so once in a while you need to unplug it from the wall.
