Author Topic: [Rigol DS1000Z] Visualizing jitter between PPS signals  (Read 1981 times)
Offline MatTopic starter
« on: January 29, 2014, 05:52:48 pm »
Hey guys,
I'm trying to setup a nice visual demo of a time synchronization protocol I've been working on.
I've got three digital signals coming from different clock domains that simultaneously toggle once per second. I want to display some kind of statistical display of the jitter between them.
The scope is in Normal triggering mode and I'm playing with persistence settings :
1) Why does a sample older than 10 s not disappear when a 10 s persistence is set (seems to take much longer).
2) Is there a way to have an infinite persistence but with statistical intensity grading, like a two-dimensional histogram? I know the scope is capable of that when trigger rate is fast, but it doesn't seem to be possible in this case...
Thanks,
Mat
edit : I have also tried it on the following scopes : GW-Instek GDS-2204, Tek TDS 2024, Tek TDS 744A, LeCroy LT344, but none of them fit the bill.
« Last Edit: January 29, 2014, 05:58:17 pm by Mat »
