Thanks for all the useful replies, lots of options.
I definitely want the in-circuit measurement ability, it's supposed to help speed up testing, I don't want to buy something where I have to remove the component from the board when I've seen Dave's video where he tests those capacitors on his dumpster diving monitor in a very short time without removing parts unnecessarily.
I'd prefer to stick to the cheap mesr-100 with no discharge ability or the expensive Peak Atlas ESR range of meters with discharge ability, apples and oranges I know, but that "NEW Transistor Tester Diode Triode Capacitance ESR resistance Meter MOS PNP NPN" tool has been tested on a video on YouTube and it doesn't do all the types of components it is supposed to test, improperly recognising certain components.
If I have to spend more on the Peak Atlas ESR meter because it has cap discharge function, will it do all caps? I suspect it won't do the big 250V+ mains cap will it? There is no mention of any limit on their website, just says controlled discharge. If I was to stay with the cheaper meter(s) with no discharge ability, what method would allow discharging the big dangerous capacitors found on domestic SMPS? Would a variation on the method shown in
this video be possible, he does mention "NOT be suitable for High-Voltage/High-Energy capacitors" but doesn't specify limits.
Also it mentions two models with the following
ESR 0.00 - 20.0 Ohms
ESR 0.00 - 40.0 Ohms
In flat panel TVs and flat panel Monitors (and desktop/laptop motherboards - as well as any SMPS for that matter) am I likely to need up to 40 Ohm measurements or is that for industrial circumstances?
I don't want to do what I did with the soldering irons and get a decent one after my third try, and three lots of money, but I don't want to buy an over specified piece of equipment with features I will never use. Having said that it's only £12 difference in this case, so might go for it if it's necessary.
I don't fancy ordering from abroad, shipping costs, shipping times and no guarantee that I won't have to pay extra for customs import duty. Also if I had cause to return the item, it would be cost prohibitive. The exception is cheap(usually <£20) Chinese stuff, not had issues with import duty or high costs on Chinese/Hong Kong shipping so far. Had the odd 2-5week wait but it usually arrives or they send out another.
EDIT: Also - anybody used one of these and can they be bought in UK?
http://www.prc68.com/I/ESRmicro.shtmlEDIT 2:
http://www.maplin.co.uk/p/atlas-esr60-equivalent-series-resistance-meter-and-capacitor-analyser-n43bj This looks to be a good price and it mentions more about the "abuse voltage" which I assume relates to discharging caps. Abuse voltage (C<10µF) ±400V | Abuse voltage (C>10µF) ±40V.
I'm assuming this is no better than the 50Watt resistor method in the video above.
