A common problem with the TDS620A Tektronix scope is that it will pass all startup test except Acquisition and/or Acquisition Interface. Yes, I know about the leaky electrolytics, and replace all before even trying the scope. However, replacing the capacitors rarely, if ever, solves the Acquisition Fail problem. Have tried to insure there are no broken traces as a result of the leaking capacitors, but the job would be infinitely easier if there were a schematic diagram available for the Acquisition board. First, does anyone know if there is any hope of obtaining a schematic for this board? I have heard the TDS520B might be similar, but looking at the board layout, it is not obvious. Any help will be GREATLY appreciated!
