If i knew howto mod the code to have it sink current for an led on a spare bp pin i would do it, i dont know, thats why i'm asking here ok.
OK, well, if you really need it, send @fredo_ a message to ask him to help you with this request in question FW mod.
-as I look at the last .ioc the PA15 is empty and there is a meaningful place to exit on the BP PIN(38) as well...
unfortunately the loadable pins are not usable in this BP configuration (are in use) PC13 BP board LED (fredo PPS), PC14 & PC15 for OSC, so you need a
small circuit in front of the LED
(otherwise there are only 3 open drains (only 3mA)
this can be many things, but use a single TI Schmitt-Trigger Buffer SN74LVC1G17 to give the right current to any type of LED (cca. 24mA enough for all)
In CubeMX, need to generate the STM32 HW configuration to the corresponding C code, then write a code (@fredo_) to raise (high) the PA15 in GPS lock state and the buffer will drive your LED
