Sorry for the lack of technical knowledge I'm sure to show here, I'm a software guy who occasionally needs to measure things..
I've owned a 121GW for a few years now, and while its been very lightly used, its always worked perfectly.
I came to use it this morning to measure current on a 4-20mA device, and I have a strange issue (to me).
When I select mA on the dial, and select DC, the display shows ~12.52mA (sometimes 12.50 or 12.51) with nothing connected except the leads, if I then short the probes I get 0mA as expected, but if i try to measure a 20mA signal being generated by my device, I still only get the 12.52 mA shown.
If i select AC, I see 0.0mA on the display.
If I remove the probes, it still sits at 12.52mA
I've tried new batteries, and also re-loaded the calibration from SD from a backup I took when I first bought the device. With no improvement.
Resistance and Voltage Measurements all seem fine from what I have tested.
Anyone know what else I could try? (V 2.05 (this is what it shipped with), S/N: 210403148, Maybe 5 Hours Use total!)
